Welp, decided to ATTEMPT to lower my car here at work, started at 4:44. Just finished the driver side front. These bolts are WAYYYYYYYYYYYYY too hard to turn, I just flat out can't turn them. Is there ANYYYY way to make them easier to turn? I really wanna go home and eat dinner, then go out, but it looks like i'll be pulling an all-nighter if I don't get this fixed!
When lowering the front of a C5 (especially on older cars) many people are unable to turn the bolts. With the car jacked up & ready to lower (as in previous tips), place another small/standard jack under the end of the spring & jack it up enough to relieve some of the tension on the spring. This will allow the bolts to turn VERY easily with an open end wrench (or sometimes by hand). A small wood "block" between the jack & spring will protect the spring from possible damage. I also found it was not necessary to remove the front wheels.
