Different Brake Fluid??
Old Jan 8, 2006 | 09:21 AM
ArmyVette's Avatar
ArmyVette
Default Different Brake Fluid??
Picked up some DOT 4 yesterday because I couldn't find any DOT 3. There wasn't even a place on the shelf for DOT 3.
Are DOT 3 and DOT 4 brake fluids interchangeable?
Old Jan 8, 2006 | 09:57 AM
rws.1's Avatar
rws.1
DOT 4 and DOT 3 are compatible. They are both glycol ether based. DOT 4 has a higher boiling point because it is borated.
BUT DOT 5 fluids are silicone based and NOT compatible with DOT 3 or DOT 4
Old Jan 8, 2006 | 01:22 PM
Lancer033's Avatar
Lancer033
I've been using DOT 4 in the brakes and clutch for over 2 years now.
The only thing about DOT 4 is that usually it needs to be replaced more often, if memory serves me correctly, DOT 4 should be flushed every year while DOT 3 can stay in the car for 2 years. Doesn't matter much to me though, longest brake fluid is in my car is about 4 months over the winter.
To Different Brake Fluid??
