SCCA "stock" classification
Old Jan 8, 2006 | 09:25 AM
technolud's Avatar
technolud
Default SCCA "stock" classification
Does anyone know if adding Z06 springs and or swaybars to a 99 M6 coupe will bump you out of the SCCA stock class? My understanding is that the option of these bars only came with the hardtop cars.
Old Jan 8, 2006 | 09:48 AM
TedDBere's Avatar
TedDBere
You can use the front Z06 bar (any front bar is legal in Stock). The rest will bump you out of stock since the coupe could not be ordered from the factory with the Z06 springs and rear sway bar.
ASP with the springs and rear bar.
Old Jan 8, 2006 | 09:52 AM
technolud's Avatar
technolud
Hardly seems fair. Already running at an 80 pound weight disadvantage, 60 hp down and more body flex. Ought to be able to run the same bars, springs and wheels since its in the same class.
Just have to learn to drive better I guess.
To SCCA "stock" classification
