Trouble after washing... help
Old Jan 8, 2006 | 06:48 PM
RdDragn2's Avatar
RdDragn2
Default Trouble after washing... help
I washed the engine bay of my car yesterday with a hose and Simple Green because it was a tad on the dusty side. When I went to go drive it today, it started and idled just fine and normal, but when I was driving it and opened the throttle up more then about half the car started to surge. The car also seems to have a less power in the low end also. Have I done any perminant damage? How can i fix it?
Old Jan 8, 2006 | 06:55 PM
Spacecoast's Avatar
Spacecoast
Check for any codes. Also, check all of your connections around your airbridge and intake.
Old Jan 8, 2006 | 07:04 PM
RdDragn2's Avatar
RdDragn2
My car through a front knock sensor code. And the air bridge is fine. Everything is also dry now too.
Old Jan 8, 2006 | 07:10 PM
Spacecoast's Avatar
Spacecoast
I would say clear the code and then run it again. May have just been a sensor that was wet.
Old Jan 8, 2006 | 07:11 PM
Patches's Avatar
Patches
I've posted this TSB related to engine washing several times here. It's possible your problem may be related.
1998-2002: Service Bulletin: Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set
Subject: Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set (Replace Rear Bank Knock Sensor and RTV Area Around Sensor)
Source: Chevrolet Dealer Technical Service Bulletin
Number: 02-06-04-023
Models: 1998-2002 Chevrolet Camaro, Corvette, 1998-2002 Pontiac Firebird
with 5.7L Engine (VIN G -- RPO LS1)
1999-2002 Chevrolet and GMC C/K Pickup and Utility Models (Avalanche, Silverado, Sierra, Tahoe, Suburban, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL) with 4.8L, 5.3L or 6.0L Engine (VINs V, T, Z, N, U -- RPOs LR4, LM7, L59, LQ9, LQ4)
Condition:
Some customers may comment on a mild to severe engine ping (commonly referred to as spark knock), usually worse during acceleration and/or an illuminated MIL. Upon investigation, the technician may find DTC P0332 set.
Cause:
This condition may be the result of corrosion of the rear bank knock sensor due to water intrusion into the sensor cavity. This condition is more apparent on vehicles in which customers frequently wash the engine compartment.
Correction:
Replace the rear bank knock sensor and build a dam (wall) around the sensor using RTV to divert water away from the sensor. Use the procedure and part number listed below.
Remove the intake manifold. Refer to the Intake Manifold Replacement procedure in the Engine Controls sub-section of the appropriate Service Manual.
Remove the wiring harness assembly from the knock sensor.
Remove the rear bank knock sensor.
Install the new rear bank knock sensor. Tighten the knock sensor to 20 N·m(15 lb ft).
Install the wiring harness assembly to the knock sensor.
Apply a bead of RTV silicone sealant approximately 9 mm (3/8 in) wide and 6 mm (1/4 in) high along the outside edge of the ridge on the engine block valley cover around the rear bank knock sensor. DO NOT form a complete circle. Leave the rear section open as shown.
From the underside of the intake manifold, completely remove the rear intake manifold seal (foam material).
Install the intake manifold. Refer to the Intake Manifold Replacement procedure in the Engine Controls sub-section of the appropriate Service Manual.
Old Jan 8, 2006 | 08:04 PM
dpd's Avatar
dpd
not good.your problem is there is water in the knock sensor harness connector.it is located behind the intake.there is tech bulletin on this.the fix is pull the intake,replace and reseal the knock sensor[s],clean/replace corroded terminals and don't wash the engine.
Old Jan 8, 2006 | 08:45 PM
troy144's Avatar
troy144
Old Jan 8, 2006 | 08:49 PM
NSTG8R's Avatar
NSTG8R
when will people learn not to be lazy ...
get a rag some compressed air and spend the time ..
To Trouble after washing... help
