hazard turn dignal switch failures
Old Jan 8, 2006 | 10:05 PM
oklahoma's Avatar
oklahoma
Default hazard turn dignal switch failures
I have a 2000 a4 coupe getting ready for the 3 hazard/turn signal replacement. Do any of you have solutions to this recurring problem? Perhaps a different brand switch if one exists or install technique. Thanks for any comments.
Old Jan 8, 2006 | 10:11 PM
Speedway's Avatar
Speedway
I replaced mine without dismantling the entire dash. Remove center console and remove radio. It takes some finagling, but you can reach your hand up through the top to pull the switch out.
Old Jan 8, 2006 | 10:12 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Do a quick search - solutions with pics were posted 2 days ago
Old Jan 8, 2006 | 10:14 PM
0EG@EnglandGreen
Supporting Tuner
Did it for you... http://forums.corvetteforum.com/show...d&forum_id=103
To hazard turn dignal switch failures
