Shifter Knob
Old Jan 10, 2006 | 12:55 PM
gregandcallaway's Avatar
gregandcallaway
Default Shifter ****
Can you tell me how to remove the standard shift **** from my 2000 6-speed? I want to replace it with an after-market item. Thanks.
Old Jan 10, 2006 | 12:58 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Pop the top off with a flat-bladed screwdriver and the pull the locking pin out (straight up) with vise grips. THen unscrew the ****.
Old Jan 10, 2006 | 01:33 PM
srsjuju's Avatar
srsjuju
thats the ticket
Old Jan 10, 2006 | 01:36 PM
kedvesh's Avatar
kedvesh
thats the ticket
Or, once you get the shifting diagram cap off, put a soft cloth on the edge of the shifter ****, use a flat bladed screwdriver to get underneath the lip of that "demon key" and carefully pop it off/out. Then unscew the ****.
Old Jan 10, 2006 | 04:52 PM
BuckyThreadkiller's Avatar
BuckyThreadkiller
Successful Plumber
From: Top of the hill, 3rd mailbox on the right. Texas
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
Note - the key is not welded, cemented, glued, cast in place, or threaded into the stick.
It just feels like it.
Old Jan 10, 2006 | 04:57 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
and blood, sweat and tears. You may be tempted to utter some 4-letter words... temper grasshopper.
Old Jan 10, 2006 | 05:05 PM
502ci's Avatar
502ci
Don`t pull upwards towards your face or teeth.
Old Jan 10, 2006 | 05:28 PM
JustinSwinton's Avatar
JustinSwinton
this is an EXTREMELY good point....noone likes to punch themselves in the nose....but I promise you will learn the first time!!
Old Jan 10, 2006 | 05:31 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
Information I could of used when I did mine.
ouch, hurts just to think back to that day......
To Shifter Knob
