[Z06] Dyno Question
Old Aug 5, 2001 | 01:18 AM
Ricker812's Avatar
Ricker812
Default Dyno Question
Got my bone stock 2001 Z06 dynoed today and it pulled a consistant 342 SAE Corrected horsepower...
What does that translate to at the flywheel? What is the formula?
If you assume a 15% loss in the transaxle does it equal 342/.85 = 402 ? That seems too high...
Thank you!
Rick out.
[Modified by Ricker812, 6:34 AM 8/5/2001]
Old Aug 5, 2001 | 11:05 AM
GTB/ZR-1's Avatar
GTB/ZR-1
Default Re: Dyno Question (Ricker812)
Seems too high Rick, but, that would be correct... :yesnod:
You got yourself a strong one!!!
Old Aug 5, 2001 | 12:09 PM
4cefed's Avatar
4cefed
342*1.15= 393 hp at the flywheel. So, if you did have 393 hp at the flywheel subtracting 15% driveline loses would be 393/1.15= 342 rwhp.
[Modified by 4cefed, 10:13 AM 8/5/2001]
Old Aug 5, 2001 | 12:16 PM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: Dyno Question (4cefed)
4ce ... that is incorrect...to get an approximate flywheel number you DIVIDE the rwhp by .85
and you do the inverse to do the inverse
which is 402 which is correct....nearly every stock Z06 I have seen dynoed (including both of mine) have been in the 400 to 405 range
congRATs
Old Aug 5, 2001 | 05:48 PM
GTB/ZR-1's Avatar
GTB/ZR-1
Default Re: Dyno Question (Ram Air Tony)
Joel,
Tony is correct on that. Aaron will be calculating your FWHP using the same method. RWHP/.85 = approx. FWHP
Old Aug 5, 2001 | 06:29 PM
GaryZ06's Avatar
GaryZ06
Default Re: Dyno Question (GTB/ZR-1)
Ricker812 those are great numbers.....How many miles does your beast have?
Old Aug 5, 2001 | 08:49 PM
4cefed's Avatar
4cefed
I stand corrected. I hadn't had my coffee yet. :bb
Old Aug 7, 2001 | 12:13 AM
Ram Air Tony
4ce...trust me Buddy....if that is the biggest mistake ya make .... U GOT IT MADE BROTHER !!!!!!!!!
$hit, I screw up more than that daily....as in everytime i open my mouth to my wife.....cant win for losin with her a$$ :bb :cry :crazy: :mad
but i am still an :blueangel:
hehehehehhee
thanks
R
A
T
To Dyno Question
