PM's
Old Jan 11, 2006 | 07:07 PM
White Six Speed's Avatar
White Six Speed
Default PM's
For some reason, for the last couple of days I can not reply to PM. Only recieve them. Has anyone else have this problem. When I try to send the reply after i write it it does not go thru.
Old Jan 11, 2006 | 07:09 PM
LS1MN6PEWTER's Avatar
LS1MN6PEWTER
your box might be full or your just not saving your sent pm copies...
they changed the options a bit on the site so now you have to check the button in your pm options for the sent pms to save, but they might still be sending just not saving in your sent folder.
Old Jan 11, 2006 | 07:14 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
How do you know it doesnt go through? Is it because it wont let you? OR because it doesnt show up in the sent box. If its the second part, its because they changed the program of the PM box. Now when you send a PM you have to check the little box below the reply that says
"Save a copy of this message in your Sent Items folder." If you dont, it will STILL go through it just wont save it. Its designed to save on PM box space..
Old Jan 11, 2006 | 07:21 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
asked and answered...
To PM's
