Check Engine Light (lean mixture)
Old Jan 11, 2006 | 08:17 PM
John Walton's Avatar
John Walton
Default Check Engine Light (lean mixture)
Hi All-
A friend has a 97 corvette with a check engine light that comes and goes. The code was checked and came up with lean mixture (cannot remember what the code number was). He is running premium gas, and the oxygen sensors were ok. The next test is to check if there is a vacuum leak somewhere. What is the best way to do this? Are there any other problem to look out for?
Thanks.
Old Jan 11, 2006 | 08:19 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Check and make sure the air bridge is on good
Old Jan 11, 2006 | 08:28 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Could be a crack in the exhaust before the O2 sensors...
This would show lean and run rich (computer trying to compensate)...
Old Jan 11, 2006 | 08:49 PM
ls1vette97's Avatar
ls1vette97
I bet you thats the problem, it happened to me! My MAF airflow sensor had actually disconnected for the airbridge. Hope this fixes your problem.
Old Jan 11, 2006 | 09:39 PM
John Walton
could the maf sensor be dirty? can this be cleaned?
Old Jan 11, 2006 | 10:03 PM
LoneStarFRC's Avatar
LoneStarFRC
Also check fuel pressure. If too low could be a sign of pump problems or pressure regulator problems too. HTH
Old Jan 12, 2006 | 01:34 AM
01QuickSilver's Avatar
01QuickSilver
I recently had the same problem on my 97 Chevy pickup. A good friend who is also a GM tech correctly diagnosed the culprit to be a restricted fuel filter. The engine leans out momentarily and throws this code. Changed fuel filter, erased fault code and no more problem.
No guarantee but this is a cheap place to start....Good Luck
To Check Engine Light (lean mixture)
