led tail lights
Old Jan 11, 2006 | 08:55 PM
boss31's Avatar
boss31
Default led tail lights
I purchased a set of led tail light from Makoto auto trends about two month ago. I just put them on and they look great but the turn singals flash real fast and that is driving me insane. How do I stop that from happening? I called the place up and they said they will give me my money back but I don't want to get rid of the lights because they make the car look good. So please help. Thanks inadvanes John
Old Jan 11, 2006 | 09:20 PM
georgehafe's Avatar
georgehafe
NCM Ambassador
Cruise-In 1, 2, 6, 8 Veteran
You need the special flasher to go with it. Your car is thinking that there is a light out on your signal due to the much lower volts the leds use. The fast flash is just the way the car tells you there is a light out.
Old Jan 11, 2006 | 09:34 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
You can use a load resistor on the powerside of the two outside lights.
call webelectric see if they will sell you a few.
Connect power load resistor to ground and you should be ok the current draw is not high enough.
turn signal +-----{resistor}------ground
Old Jan 12, 2006 | 06:22 PM
boss31's Avatar
boss31
where can I buy the flasher
To led tail lights
