5th Bow Seal
Old Jan 12, 2006 | 04:47 PM
BIG ATLANTA's Avatar
BIG ATLANTA
Default 5th Bow Seal
I have a 2000 vert and the seal needs replacing. It is starting to rub into the top and into the paint. i have a few questions
1- How much does this seal cost my dealer says $600
2- Will my GMPP warranty cover the repair?
3- I thought I saw a "service bulletin" on this about 6 months ago where the repair was under warranty
Any and all help is appreciated Thanks!!!
Old Jan 13, 2006 | 10:19 AM
waupachino's Avatar
waupachino
The weatherstrip piece should only be about $80 wholesale, around $135 retail if I remember correctly. I need to do mine also but have never got around to it yet. Mine is still under GMPP warranty, and I was told it does not cover weatherstripping and would have to pay for it myself.
Old Jan 13, 2006 | 10:22 AM
white top's Avatar
white top
Seal retails for about $100 but you could order from F. Beans and get it for less.If your car is still under warranty dealer should cover it if not you pay. TSB just tells tech what to do.
Jerry
Old Jan 13, 2006 | 01:28 PM
Hammie's Avatar
Hammie
Just did this myself, so PM me if you have any Q's. Went through it last weekend.
1) Like 75$ from fred beans plus S&H. Retail from dealer is about 130.
2) Nope, GMPP does not cover weatherstripping.
3) http://www.corvetteactioncenter.com/....php?qstId=214 That's your link right there. The warranty there is the original one. GMPP will not cover.
When doing the job, you have to find the nuts by removing some foam that covers them. You'll see what I am talking about when you get the new seal. Give yourself about 30 mins for the swap. Pull te foam off, undo the two nuts on each side, pull the seal out. Next find the way that best suits you to push the new seal in. I liked hook the bottom edge in while pressing the top down with a small flat-blade screwdriver all the way around. Next, screw the nuts back onto the new seal and sover them with the foam (I used some windshield sealant to hold the foam in place, as the double-sided tape would not hold) GL, it's cake really.
Old Jan 13, 2006 | 03:31 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
To 5th Bow Seal
