Why not go back to runflats?
Old Jan 12, 2006 | 04:49 PM
jayr2k's Avatar
jayr2k
Default Why not go back to runflats?
I have a 2000 with 8900 miles on it, I haven't had any problems with the tires( I know it only has 8900 miles on it) But why does it seem like everyone who changes tires goes away from the Goodyear F1gs runflats(oem tires)? Is it just a change of pattern for looks or am I going to have some trouble with mine?Just wondering.
Old Jan 12, 2006 | 04:53 PM
Tenderfoot's Avatar
Tenderfoot
Run flats have a stiff sidewall and that most people experience bump steer with these tires as they tend to jump sideways if you are changing lanes or in a turn and have less than a glass smooth road surface. Second compliant is that the runflats are louder (tire noise) as compared to non-run flats, especially as they wear more (true of any tire). Third, non-run flats generally offer better handling/grip in both wet and dry conditions.
Old Jan 12, 2006 | 05:06 PM
99 TorchRed's Avatar
99 TorchRed
Those reasons are true, but IMHO, the main reason many look at non-runflats as replacements is price.
Old Jan 12, 2006 | 05:10 PM
MTurnbo's Avatar
MTurnbo
Old Jan 12, 2006 | 05:13 PM
Tire noise, ride, handling are all reasons to go away from the runflats. However, I will admit that the security they offer is very reassuring.
Old Jan 12, 2006 | 05:15 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Old Jan 12, 2006 | 05:17 PM
EStreeter's Avatar
EStreeter
I am considering the change to non-RFs. I have 25,000 miles on my 03 and the OEM tires still look pretty good but I will probably be buying tires this season.
Why switch?
1. They are noisy.
2. They ride hard.
3. Bump steer is a pain.
4. Traction not to good.
5. I can't remember the last time I got a flat tire - with any car. I bought a small electric tire pump, got a small scissor jack and some plugs. In an emergency I figure I could get air back in the tire and drive to a repair center easy enough.
6. Price. Price. Price.
I may be sorry for the switch but I'm going to give a try.
Old Jan 12, 2006 | 06:34 PM
jayr2k's Avatar
jayr2k
Thanks alot guys when I get new rubber I'll remember
Old Jan 12, 2006 | 06:48 PM
MTurnbo's Avatar
MTurnbo
Just as soon as you switch to non-runflats.
Old Jan 12, 2006 | 07:26 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Do a ride along with someone that has non runflats ... you'll be amazed at what you don't hear ... as compared to what you can't hear. The ride is better as well. Compare your options.
Old Jan 12, 2006 | 07:36 PM
Lank's Avatar
Lank
I ran over a piece of steel in the road one Sunday night 210 miles from home and cut the right rear so bad that it could no way be plugged.
We drove home that night with 0 pressure in that tire without any problems at 55 MPH.
We take alot of long trips in our vette and I'll always have Goodyear runflats just for the peace of mind.
Old Jan 12, 2006 | 07:40 PM
jimmie jam's Avatar
jimmie jam
run flats are fine. most noise comes from over-inflation...on any tire BUT run flats especially. 30 psi HOT and they're fine for me. sure they are not "cheap" but 93 octane fuel isn't AND corvettes aren't cheap! run flats forever!
Old Jan 12, 2006 | 07:47 PM
BELVIN20's Avatar
BELVIN20
Have driven Vettes with run flats and non run flats, no doubt non run flats are quiter and ride better, however, I like others take long trips and feel better with run flats. But there are other brands of run flats that are better than Goodyear such as a Michelin.
Old Jan 12, 2006 | 08:00 PM
Anomir's Avatar
Anomir
You can also get something other that the GY, which are crap. Michilen has a very nice one for example and keep your runflat capability.
Old Jan 12, 2006 | 08:22 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
Just put a set of Michilen A/S ZPs on my 04. WAY less noise. Better ride. I'm sure they don't have the grip of some of the better non RFs, but for 90% of my driving, they work really well. I'm considering another set of wheels with something really sticky for cruising and track days. On longer trips... I really like the RFs.
Old Jan 12, 2006 | 08:25 PM
Lancer033's Avatar
Lancer033
Why not?
-lower performance
-more noise
-more $$
-harsher ride
the only time you will ever want to have the runcraps on your car is if you have a flat and happen to be close enough to a place that can actually repair them. Other than that, they are a total waste.
Old Jan 12, 2006 | 08:26 PM
JTJ's Avatar
JTJ
St. Jude Donor '08-'09
Count me in on this one
To Why not go back to runflats?
Old Jan 12, 2006 | 08:27 PM
beltfed21's Avatar
beltfed21
Default spare from GTO works on C5 front or rear!
There was an earlier post that says that the spare for the new GTO will fit on either the front or the back of the C5 (you have to slightly drill out the center opening to make it fit). I have a coupe with plenty of room to carry this type of spare along with a small jack, so I'm thinking about doing this. I'm pretty sure one stock wheel/tire would fit back there, should I have a flat. I'd hate to have to lift it in there by myself though. I'm a weak woman!
Old Jan 12, 2006 | 08:29 PM
RTSVET's Avatar
RTSVET
Originally Posted by Lancer033
Why not?
-lower performance
-more noise
-more $$
-harsher ride
Old Jan 12, 2006 | 08:58 PM
bekdad's Avatar
bekdad
Make sure you figure out a way to secure that GTO spare, so it doesn't become a missile - and take off your head - in an accident.
