Active Handling
Old Jan 13, 2006 | 06:04 PM
bill bradford's Avatar
bill bradford
Default Active Handling
Can anyone explain exactly what active handling is. I know there is a difference from traction control. I just am confused about what the difference is.
Old Jan 13, 2006 | 06:06 PM
LiquidDI's Avatar
LiquidDI
basically active handling is working while you are at speeds. It understands if the car is losing traction and brakes certain wheels. Traction control is from a standing start. Helps keep the wheels from spinning.
Old Jan 13, 2006 | 06:42 PM
rws.1's Avatar
rws.1
Acting handling is a set of algorithms programmed into the cars computer that compare the direction of movement of the car to the direction of the steering wheel. When the sensors pick up a directional movement that the computer (using the algorithms) determines is differrent than the intended direction, it cuts power to the wheels and applies antilock braking to the appropriate wheels in an attempt to correct the deviation in movement from the intended direction.
It has limits to its capabilities and you can overdrive the active handling system.
Old Jan 13, 2006 | 06:46 PM
bill bradford
thanks, That helps much
Old Jan 13, 2006 | 07:13 PM
cebars's Avatar
cebars
The 2002 Owner's Video had a segment by Dave Hill on active handling. If you do not have the Video, you can see that part dealing with active handling on the media section of Z06vette.com. The file is 02_2_hi.wav.
Old Jan 13, 2006 | 07:15 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
[QUOTE=LiquidDI Traction control is from a standing start. Helps keep the wheels from spinning.[/QUOTE]
And between Sifts for us A4 guys.
Old Jan 13, 2006 | 07:27 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Here is a good article to read.
Paul
http://www.idavette.net/hib/ah1.htm
Old Jan 13, 2006 | 07:30 PM
bill bradford
Fantastic thanks so much
To Active Handling
