Heads/cam project complete, turned key...........
Oil pressure came right up, lifters chattered a little at first then settled down. No smoke, strange noises, or anything out of the ordinary. Holy ****. I was a little worried, but pretty confident because I was thorough. I will just give you the highlights of what I did all at once (and for the first time).Under construction:
Completed:
Futral F11 Cam
FMS hardened pushrods
New LS2 timing chain
New Lingenfelter oil pump (much more pressure than my old stocker)
New Manley dual spings, titanium retainers, hardened spring seats
New valve seals
Ported and polished the heads
Cleaned, pistons, intake, etc.
New valve cover gaskets
New Melling lifters
Ported & polished the throttle body
New radiator, flush and replace coolant
New ASP underdrive pulley & belts
New A/C compressor, evacuate system and recharge
New Front O2 sensors
New B & M supercooler transmission cooler
Changed tranny fluid to Mobil 1, installed new filter
Changed differential fluid to Royal Purple
Installed new Fuddle Racing 3400 stall, torque converter
Oil change, Mobil 1 & filter
New rear brakes
Lapped valves & seats
Installed new fuel filter
Fixed parking brake
New PCV valve
New NGK TR55 spark plugs
All of this came to less than $3,000.00. Good deal, huh?
Whew, having a nice cold one now
, well deserved. Not one leak, problem, no codes, and wails like a banshee! Won't idle for **** though. Next up, dyno tune. Thanks to everyone who answered all my questions and helped out.
,............................OH YA,....................you probubly have an awfull lot of people wanting the stats.......witch heads,..........cam................flow #s,..... H.P.???
,............................OH YA,....................you probubly have an awfull lot of people wanting the stats.......witch heads,..........cam................flow #s,..... H.P.???My stock LS1 heads, I ported them
flow numbers, no idea, I don't have a flow bench
HP, don't know yet, dyno tune as soon as weather is decent, I just detailed the car also.
Engine pr0n
Micah
Really nice lope to it with the 112 LSA. Bigger cam? I don't think so, I think I got it right.
Or should I say a few sets. I can roast the tires at will, no brake stands necessary. Just hit it, and I don't even mean to the floor. I don't know how I could even hook up with 3.73's. I think I'll just stay with my 2.73's, enjoy the mileage and less abuse on the engine. The whole hood shakes, the car shakes,
talk about "seat of the pants". Oh yeah, the wife is gonna bitch, but WTH, it's worth it.Overall, I'm really, really happy with it. It's going to be a good summer.
