What is this piece called?
Old Jan 14, 2006 | 04:55 PM
terlox's Avatar
terlox
Default What is this piece called?
First of all I'd like to thank cbx1047cc for the awesome engine shot. I hope he doesn't mind me using his picture.
So while installing my headers this past weekend I broke the little black plastic piece coming off the unit pictured below. I need to buy a replacement but I don't know what it's called or what it does. Thanks!
Old Jan 14, 2006 | 05:01 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
it looks like a figamhajig.
TTT for you while im acting stupid
Old Jan 14, 2006 | 05:03 PM
IDM's Avatar
IDM
It looks like the knock sensor but take that with a grain of salt
Old Jan 14, 2006 | 05:11 PM
usnskeet21's Avatar
usnskeet21
Your water temp sensor. Knock sensors are under the valley cover. No biggie go to the dealership shell out $50 im sure and chalk it up.
Crushinator's Avatar
Crushinator
I think it's one of those things you put in a turkey to tell you when it's done. When it pops, you're engine is warmed up. hardy har har
Seriously, it appears to be a sensor/sending unit of some sort.
Old Jan 14, 2006 | 05:14 PM
vettes4fun's Avatar
vettes4fun
Water Temp Sendor
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
A turkey popper!!
You guys are killing me!
Bob
Old Jan 14, 2006 | 05:17 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Roger that
Old Jan 14, 2006 | 05:21 PM
IDM's Avatar
IDM
Doh! I was between water temp sending unit or knock sensor. Went with knock sensor because on my last car the water temp was on the back of the thermostat housing. It was a rotary engine and thats pretty much exactly where the knock sensor was
Old Jan 14, 2006 | 05:42 PM
steve8's Avatar
steve8
Originally Posted by vettes4fun
Water Temp Sendor
Sender, remember we are into spelling today. I see your from Kentucky, you're excused.
Old Jan 14, 2006 | 06:01 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Old Jan 14, 2006 | 06:46 PM
Patches's Avatar
Patches
Coolant temp sender, as several here have already indicated. I broke the plastice connector piece in one of my many forays into taking the heads off. The replacement was only about 13 bucks, if I remember correctly. Be aware that you will have coolant pouring out when you pull it to replace it. Also, use thread sealant paste - not tape - if it doesn't already come with the paste pre-applied.
Old Jan 14, 2006 | 07:11 PM
shannanl's Avatar
shannanl
I take excepshun tu that! I liv en kentuky tu!
Old Jan 14, 2006 | 07:21 PM
Rhode Warrior's Avatar
Rhode Warrior
No, I don't mind you using the picture. The funny part is, I broke that coolant sensor as well. That's a strange coincidence.
Old Jan 14, 2006 | 10:42 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Ummm ... lest ye forget, it's the same place that your car was built!
Old Jan 14, 2006 | 11:02 PM
Rhode Warrior
I think it's supposed to be you're from Kentucky. (Since we are into spelling today).
Old Jan 14, 2006 | 11:12 PM
shannanl's Avatar
shannanl
You sir are correct!
Shannan
To What is this piece called?
Old Jan 14, 2006 | 11:13 PM
wstory1's Avatar
wstory1
Water Temp Sendor
Old Jan 14, 2006 | 11:18 PM
1 Nasty Z's Avatar
1 Nasty Z
Old Jan 14, 2006 | 11:36 PM
terlox's Avatar
terlox
Thanks for the responses guys! I'll make a stop by the stealership on Monday.
