C5 Millenium Yellow Paint Touchup
Old Jan 14, 2006 | 10:54 PM
Dave Kitch's Avatar
Dave Kitch
Default C5 Millenium Yellow Paint Touchup
Looking to buy a 2000 Millenium Coupe. Driver's side mirror has a 1 in. long scratch 1/16 in. wide at the front of the mirror that is noticeable. Can this be touched up with a touch up/clear and than rubbed out with mild compound by hand? Since Millenium Yellow is a special paint, I thought that it might pose special problems in touchup?
Dave Kitch
Old Jan 15, 2006 | 06:11 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Dave Kitch
The clear has tint in it, so it is not the easiest color to touch up.
Old Jan 15, 2006 | 06:44 PM
Richie Carbone's Avatar
Richie Carbone
I would bring it to a respectable body shop and have it done right. Shouldn't cost more than $100.00
Old Jan 15, 2006 | 08:10 PM
jgmachine's Avatar
jgmachine
how much would a new mirror assembly be???
Old Jan 15, 2006 | 08:29 PM
Sportsdude's Avatar
Sportsdude
Had to take my Vert to the shop after trying to use the touch up paint. MY Touch up paint didn't work well for me. Using touch up for places where you can't really see might work ok.
Old Jan 15, 2006 | 10:36 PM
KMeloney's Avatar
KMeloney
I'm not sure if you're asking it YOU can do this yourself, or simply if the MY can be matched ok (by, say, a professional). But I had some rocker damage fixed at one point, and you can't tell that it was done. My shop matched the MY perfectly.
Whereas the factory used tint in the clear, I think that the color can be matched in the actual paint (as opposed to in the clear).
If I were you, I wouldn't let the thought of having to have the mirror repaired keep you from getting the car.
Good luck!
-Kirk
Old Jan 16, 2006 | 01:46 AM
rickko's Avatar
rickko
Why not buy one of these and try your hand at it until you get a professional to do it right?
On the backside there is a sticker with,
17182012
79U Mil. Yellow Touch Up Paint
2000-04
printed on it.
Old Jan 16, 2006 | 03:11 AM
thug29's Avatar
thug29
I too have a Millinium Yellow 2000 C5 and have had to use that touch up paint that Rickko shows...a tip for you; pour a very small amount into a cap (I used one from an old vitamin container) and then take a book of matched and take one match out and use the back end (not the end that you would light the match) and use that paper as the brush...does that make since what I just tryed to explain? Go easy and light on the paint and gently fill in the scratch, you should not have to sand after.....good luck.
Old Jan 16, 2006 | 03:13 AM
Y2YELLOWCOUPE's Avatar
Y2YELLOWCOUPE
paintscratch.com
Old Jan 16, 2006 | 03:47 AM
edensknight's Avatar
edensknight
Great paint tip!
To C5 Millenium Yellow Paint Touchup
