St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by Don Kisamore
The system needs to be 'bled'.
If Don's suggestion does not help, check the wires that connect to the coolant level sensor. It might have accidentally come off. Also, the coolant reservoir has a magnet inside the reservoir that might be sticking. Rap gently on the reservoir...this might correct the problem.
The coolant level sensor is simply a reed switch (that the sensor wires plug into) and a magnet inside the reservoir. You can test the reed switch by removing it and holding a small magnet up to the reed. If your "Low Coolant" alarm does not go away, and your connections are good, disconnect the wiring and short the ends. This will simulate a closed reed switch and should clear the alarm. If it doesn't, you have other issues.
From: West Hollywood California ! Now Miami, Florida
Good question
i honestly do not know if the sensor is there, i did not even think about that at all .... i just but a new coolant tank from a chevy dealership .. cause my stock one was cracked. should i just obtain new sensor???
