Which tunnel plate?
Old Jan 16, 2006 | 08:38 PM
Jims2001's Avatar
Jims2001
Default Which tunnel plate?
I am buying or making a tunnel plate. What is better 3/8" aluminum or 0.134" stainless. All I am trying to do is stiffen things up. Will be putting on Bilstens and Z06 sway bars also.
Old Jan 16, 2006 | 09:09 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Check to the left of the page. There are several supporting members who supply tunnel plates.
Old Jan 16, 2006 | 10:08 PM
Jims2001's Avatar
Jims2001
I am just wandering what material would be better.
Old Jan 16, 2006 | 10:15 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
From what I remember from a previous discussion, I believe the SS is stronger, although it is a bit thinner. Anyone else?? I believe Elite Engineering has a decent plate.
Old Jan 16, 2006 | 10:48 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Elite Engineering - contact Jeff and he'll advise you on which will work best for your application and budget. www.eliteengineeringusa.com
EG
Old Jan 16, 2006 | 10:53 PM
BC_C5's Avatar
BC_C5
I like the Elite as well. The only dissapointment was I did not seem to get the sheilding effects form the long tube heat asI would have like. I installed a DEI blanket and it a lot cooler now.
Alan
Old Jan 17, 2006 | 09:01 AM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Jim,
The stiffest plate we offer is the 3/8" thick aluminum version. It has about the same heat shielding effects as our stainless steel, but is much stiffer.
I hope that helps, Jeff
To Which tunnel plate?
