Should I lower it??? See pic.
Old Jan 17, 2006 | 01:12 PM
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
Default Should I lower it??? See pic.
If so how much.
Old Jan 17, 2006 | 01:15 PM
WKMCD's Avatar
WKMCD
Originally Posted by DJN
If so how much.
Not if you're going four wheeling. Drop it all the way on the stock bolts and it will look great and handle well and still be practical. That's from personal experience.
Old Jan 17, 2006 | 01:18 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
try lowering it on stock bolts all the way, it should drop about 1 inch... see if you like it.. you can always go lower, or change it back if you don't like it.
Old Jan 17, 2006 | 01:24 PM
rcs128's Avatar
rcs128
Depends on this year's hurricane forecast for Florida...
Yea, lower it on the stock bolts. The roads down there are pretty decent, right? I'd lower mine in a heartbeat but up here in my area I'd be scraping all over.
Old Jan 17, 2006 | 01:34 PM
ORANGEBROTHERS
The roads are not bad, I've got some good size speed bumps going into my development though, I'm not sure if it'll rub on those.
Old Jan 17, 2006 | 01:38 PM
JoshVette's Avatar
JoshVette
All the way on stock bolts is what I did. I love the look, couldn't look any better.
I scrape a bit, but you learn how to drive it and where not to drive it, no real difference from what I've been doing though.. sorry, I haven't got any recient pics of it.
Old Jan 17, 2006 | 01:49 PM
ORANGEBROTHERS
So how do I lower it, should I just crank-down on the bolts until they stop?
Old Jan 17, 2006 | 02:12 PM
black2KC5vette's Avatar
black2KC5vette
Default lol..................very funny
Very funny regarding the hurricane...............lol.
Old Jan 17, 2006 | 02:24 PM
mkiv808's Avatar
mkiv808
Do a search for "stock lower bolts", there's articles on the forum.
Or go here: http://www.z06vette.com/diy_lower.php (same on Z06 as any C5)
Old Jan 17, 2006 | 02:31 PM
ORANGEBROTHERS
Thanks, that's real easy.
Old Jan 17, 2006 | 02:38 PM
WKMCD's Avatar
WKMCD
I agree. DC area roads suck!!!!!
Old Jan 17, 2006 | 03:11 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
It is. Make sure you take the tension fully off the front spring before tou try to turn the bolt. It seems like half the people that lower their cars end up posting that they can't turn that bolt and it must be seized. BTW- I have a pit and did this entire job without lifting the car or taking off a wheel. It is that easy.
Don't skip the alignment too long or you'll chew the insides of the front tires off in no time.
Old Jan 17, 2006 | 03:18 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Lowering is more easily accomplished when you take the tension off the springs all around, even the rear.
Also the car is designed with a natural stance that has the rear a bit higher than the front. It is possible to end up with the rear equal to or lower than the front and this IMHO results in a horrible ride where it feels as if you are carrying a load of brcks in the rear of the car.
Try to measure before starting and keep a similar stance after lowering. I lowered mine more than I should have but went back and raised the rear a thread at a time to achieve the ride I was comfortable with.
Make sure you leave about two threads exposed on the rear bolts after lowering and the front ones just crank down until you cannot turn them any longer.
Good Luck!
Old Jan 17, 2006 | 03:29 PM
LiquidDI's Avatar
LiquidDI
lower it on the stock bolts. Takes 15 minutes and drops it the perfect height of 1 inch.
Old Jan 17, 2006 | 03:33 PM
Sportsdude's Avatar
Sportsdude
Try lowering it on sock bolt first and see how you like it.
Old Jan 17, 2006 | 03:35 PM
DaBeast's Avatar
DaBeast
please lowere it atleast on stock bolts
Old Jan 17, 2006 | 03:40 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Lower that thing before you put someone's eye out!!!
To Should I lower it??? See pic.
Old Jan 17, 2006 | 03:55 PM
IDM's Avatar
IDM
LOL 15 minutes? Come on, don't lie or are you superman? Maybe the rear is easy but the fronts ouch!
Old Jan 17, 2006 | 04:03 PM
ORANGEBROTHERS
Old Jan 17, 2006 | 04:04 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
yes...maybe 1.5" all the way around
