[Z06] Heads-Only ?
Old Jan 17, 2006 | 11:57 PM
Closer_2001's Avatar
Closer_2001
Default Heads-Only ?
I have an 05 CTS-V and won't be satisfied before it is making 400 hp to the ground.
It is about to get 1 7/8 Kooks, tuning, airbox, etc...That should put me at 380 ish.
The question...how to get the extra 20 ponies or more and have STOCK idle?
Option #1:
Any of the stealth cams: MTI Stealth II, CheaTR, GT2-3, Katech
Option #2:
Ported / Upgraded Heads.
Understandably, the ported heads cost more.
Any thoughts or Dyno results? We see tons of cam-only threads, but not many heads-only.
Old Jan 18, 2006 | 12:37 AM
REDLYNER's Avatar
REDLYNER
Subscribed to the thread.
I'm looking at the same option for my 01 Z. Intake, kooks 1 3/4s, hf cats, tuning.
Curious about the heads only option.
Old Jan 19, 2006 | 01:43 PM
Closer_2001
Tuners? Anybody?
GM Hi Tech did a stock 99 C5 w/ 70k miles and saw 37 rwhp using AFRs That was the 198/200 cam. I could only imagine the LS6 cam w/ headers could take advantage of the compression and ports.
How about input from...
EDC
AFR
CNC'd LS6
Patriots
I want my innocent, quiet Caddy to unleash some fury without shaking my clients out of their seats or breaking valve springs.
Old Jan 19, 2006 | 02:02 PM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
One of the guys from Speed Inc. (Larry: shop manager) bought a Z06 and didnt want any kind of choppy idle cam and wanted stock drivability out of his car, He added the cam, Longtubes, pulley, air intake and tuning and the car made 423/398 to the wheels and drives like stock, very slight lope at idle and barely noticeable, hell the stock cam in the Z06 makes the car shudder slightly at idle. I believe this is the 007 cam listed on the websight
www. ls1speed.com
I will most likely be adding this to my set up in the next month or so when the weather breaks here.
Old Jan 19, 2006 | 02:10 PM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
I've wondered what the following would make on an LS6 with stock cam:
AFR 205
Nice long tubes like LGMs
1.8 rockers
Port tb
LSX intake
Good airbox like Vararam
Anyone's guess.
Old Jan 19, 2006 | 02:23 PM
DT's Avatar
DT
Howdy!
I'm almost positive (maybe you can find it using the search, I tried with no luck) that someone did this down in Orlando, I was thinking it was at Mike's shop (NLP). All the boltons (headers, pulley, intake) with AFR205 heads and a 02+ spec LS6 cam for ~404rwhp.
Also on the other site(s) some tuners in IL reported doing ~420 again, with aftermarket heads, stock LS6 cam. The indication was it idled basically like a stock LS6.
Of course in either case, a really good tune!
Old Jan 19, 2006 | 07:24 PM
ZO6PARTS's Avatar
0ZO6PARTS
Supporting Vendor
Default My 1999 FRC Hahahahaa
My 99 Hardtop did 411rwhp and 380 torque through........STOCK MANIFOLDS!
Here is the build-Lpe Heads,Gt2-3
http://www.z06vette.com/forums/showt...t=83571&page=5
Old Jan 20, 2006 | 07:49 PM
Closer_2001
That is strong!
The LPE GT2-3 Cam did really well in a few GTOs as well.
Closer_2001
Originally Posted by DT
Howdy!
Cool thanks!
Old Jan 21, 2006 | 12:41 PM
B R's Avatar
B R
From: Los Angeles, CA.... I know a guy who has a Lambo with Corvette doors
Option #3: S/C .
Old Jan 21, 2006 | 05:29 PM
User 81424's Avatar
User 81424
If money is not an issue you can't go wrong with head cam package. Call all the tuners up, they will tell you what HP you can expect.
Old Jan 21, 2006 | 07:16 PM
ksett's Avatar
ksett
I would go with AFR 205's shaved to 11:1 compression and skip the Kooks and go with LG Pros. I would guess you will be easily over your goal with this setup.
Old Jan 22, 2006 | 09:58 AM
DT's Avatar
DT
Does LG do his headers for the CTS-V (didn't know if you noticed but he has a Caddy!)? Didn't see them on the website.
DT
To Heads-Only ?
