2003 door panel removal
Old Jan 18, 2006 | 10:34 PM
9vat7's Avatar
9vat7
Default 2003 door panel removal
Hi Guys:
Does anybody know how to take off the door panel?? I am having trouble with my driver side door lock. The FOB unlocks the door but will not lock it. The door unlock button will unlock both doors but will not lock the driver side. so I figure it must be the module that has something wrong. Any help would be greatly appreciated.
Thanks in advance to all
Old Jan 18, 2006 | 10:47 PM
Mickbee's Avatar
Mickbee
Originally Posted by 9vat7
Hi Guys:
Check out Ken King's site
Good luck!, http://www.vetteessentials.com/. He has the steps to remove the panels and they are very straight forward.
When prying the panels off, I would recommend not using tools of you can avoid it to reduce the chance of scratching.
Old Jan 18, 2006 | 10:52 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
They have excellent write-ups of various interior pieces to be removed.
Old Jan 19, 2006 | 01:33 AM
MrLeadFoot's Avatar
MrLeadFoot
Hi Guys:
Because several of us just went through the very same thing, I thought I'd offer up some info I learned, to hopefully save you some time and money.
It's the relay on the door module board. Choices:
1) De-solder out the old one, and solder in a new relay. $1.30 each relay + shipping and handling (Digikey.com). See link below for part numbers and entire thread on the issue:
http://forums.corvetteforum.com/show...post1553527488
(You might as well order 4 relays, and do both relays on the driver's door, saving the other two for the passenger door. Replace the relay closest to the edge of the board, and the one right above it.)
2) Contact Gene at www.geneskarshop.com. About a week ago he quoted me $75 for a pair of used door control modules for my '01.
3) Take it to the stealership for diagnosis $96
4) Buy a new module for $278 from the stealership.
5) Have the stealership do the swap. $600 - $700.
I went for number 1, which was quite easy, except that I struggled at the de-soldering the old ones off, the satisfaction of doing it without getting ripped off at the stealership....... priceless!
To 2003 door panel removal
