[Z06] Need some help with the FAQ.
Old Jan 20, 2006 | 08:46 PM
User 81424's Avatar
User 81424
Default Need some help with the FAQ.
I need some one to give me a write up on the Z16, the differences, the CF hood, etc. for the FAQ please.
I added a Table of contents:
Post #! Tranny info, fastener torque specs, alignment specs, and corvette forum acronyms
Post #2 Torsional rigidity and the fixed roof coupe.
Post #3 General C5 info
Post #4 Difference between 01 Z06 and C5
Post #5 Difference between 01 and 02 (02 & 03 the same)
Post #6 Difference between 02/03 and 04
Post #7 Do you want to track or auto cross your Z06?
Post #8 C5 Tech tips
Post #9 2d Generation Active Handling
Post #10 2001 oil consumption problems
Post #11 C5 and general audio FAQ
Post #12 Steering Column Lock FAQs/Also known as, Pull key wait ten seconds
Post #13 How to lower
Post #14 Head CC volume vs Compression Ratio
Post #15 All the LS1/6 cam shaft info you could ever want.
Post #16 Maximum tire sizes
Post #17 Ram air and cold air filter systems
Post #18 Gasoline and octane facts.
Post #19 C5 Heads Up Display Retrofit
Post #20 Install a CD Changer
Post #21 Engine and tranny oil discussions
Post #22 Aftermarket body pieces, paint, wheels, etc.
Post #23 How to add fog lights
Post #24 How to remove your license plate frame
Post #25 Flat tire repair and a spare for the Z06!
Post #26 Z06 cabin partitions
Post #27 How to read tire info
Post #28 DIC codes
Post #29 Will modifications void your warranty? MAGNUSON MOSS WARRANTY ACT
Post #30 2004 color production info
Post #31 Charge System Fault Message
Post #32 Z06 gas mileage
Post #33 Clutch pedal soft, sticks to the floor?
Post #34 8 inch subwoofer in the door
Post #35 Various Z06 accessories
Post #36 How to use a "Sharpie" pen to color lettering on your dashboard
Post #37 Campbell Hausfield air/water separator PVC mod
Post #38 C6 shifter in a C5
Post #39 Water dripping from AC under the dash
Post #40 Would you drive your Z06 in the snow?
Post #41 All the C6 Z06 specs are here
Post #42 How to change pads and rotors, and other brake info.
Post #43 History of the Corvette name and symbol
Post #44 Z06 and other wheel weights and sizes
Post #45 Picture Tutorial Helping YOU take better pictures of your C5
Post #46 Me at the Nurburgring
Post #47 Transmission service bulletin
Post #48 Scratch or damage a wheel?
Post #49 How to polish your Route 66 tips
Post #50 Is it Z oh 6 or Z zero 6?
Post #51/57/58 C6 Z06 brakes on a C5
Post #52 Differential/axle seal leaks?
Post #53 X or H pipe
Post #54 How to polish your Ti exhaust tips
Post #55 How to distinguish between LS1 and LS6
Post #56 Is a Z06 just a C5 with bolt ons?
Post #59 iPOD your car
Post #60 Clear corner light install how to
Post #61 How to add tire pressure sensors
Post #62 Did this fall off your Z06?
Old Jan 20, 2006 | 11:14 PM
xilr8n's Avatar
xilr8n
Z16 option package
• Unique Le Mans Blue Metallic exterior paint
• Unique carbon-fiber hood
• Black interior with Commemorative seat embroidery
• Special exterior badging
• Polished Z06 aluminum wheels with Commemorative center caps
• "C5-R Le Mans" stripe scheme
The hood weighs 20.5# the stock hood 31.1#
Old Jan 20, 2006 | 11:50 PM
User 81424's Avatar
User 81424
Thank you
Old Jan 21, 2006 | 11:36 AM
xilr8n's Avatar
xilr8n
Might want to mention at the top of the index that you can press control f and get a find box. type in whatever you are looking for ie: brakes and zip right to the next mention of that keyword.
Old Jan 22, 2006 | 10:48 AM
User 81424's Avatar
User 81424
Will do.
To Need some help with the FAQ.
