When I purchased my 03 coupe it came with one remote, Ebay has a ton of them for sale but they advertise remote 1 and 2 is there a diffrence and how do you program ?
Dave, I don't believe the car knows what number is on the fob. It depends on the order in which they're programmed. If you had two #1 fobs, the first one programmed would respond to #1 memory settings. The second one programmed would respond to #2 etc.
Programming instructions are in the owner's manual.
vettes will only take three FOBs into the programming mode . It does not matter what the imprint on the back of the FOB says , your car will learn 1,2,and 3 in the order you teach it .
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
My 03 came with 2 key fobs on the back of them you have a 1 and on the other you have a 2 this is for the seat setting person 1 has one fob and person 2 has another fob.You have one missing if you bought the car from a dealer they should have given you 2 fobs not one.You can also set the fobs for a third person.All this should be in your manual.
