Build date
Old Jan 21, 2006 | 06:44 PM
denali's Avatar
denali
St. Jude Contributor
Default Build date
Hows the best way to find the build date on a particular vette??
Old Jan 21, 2006 | 07:13 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
On the sticker on the door, I think?
Anyone else chime in?
Old Jan 21, 2006 | 07:23 PM
troy144's Avatar
troy144
isn't there a sponge vet guy, or something like that that runs these through his computer...I have seen him do it for others
Old Jan 21, 2006 | 07:31 PM
reb854's Avatar
reb854
your buildsheet is located inside the front metal rebar inside the front bumper normally on the drivers side, you can take the lower splashield off under the bumper and reach it. This sheet will tell you everthing as far as options. etc.etc. most of it is coded. yor local dealer can disect the vin for you as well good luck!
Old Jan 21, 2006 | 07:33 PM
denali's Avatar
denali
That would be very nice. I just looked on the door & it's not there.
Old Jan 21, 2006 | 08:01 PM
troy144's Avatar
troy144
Hi. You know what I did... I went to the National Corvette Website and went to build sheets. They sell this laminated, and a reproduction laminated window sticker. It is not cheap but they look good, like a dinner mat. I think I spent like 60 bucks. It took like two weeks to get but they look good, if you are going blow some money I guess it is worth it. I did. Hope that helps, it is a rip if you go this route but hey it's a Corvette.
Old Jan 21, 2006 | 09:14 PM
Sponge Vette's Avatar
Sponge Vette
Post your vehicle number and I'll look it up for you.
Old Jan 21, 2006 | 09:20 PM
denali's Avatar
denali
1G1YY32G135120462
Old Jan 21, 2006 | 09:24 PM
Sponge Vette
Originally Posted by denali
VEHICLE INFORMATION
Merchandising Model : 1YY67 -2003 CORVETTE CONVERTIBLE Warranty Start Date : 05/23/2003
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : HATCHER CHEVROLET, BUICK, PONTIAC, OLDSMOBILE, GMC TRUCKS, INC.
PO BOX 218
BROWNSVILLE , TN 38012-0218
(731) 772-9082
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 05/23/2003 70 miles 05/23/2006 36070 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/30/2003 A20462 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1670 kg (3682 lb) Order Number : FVXJX2
Build Date : 01/30/2003 Build Plant : 135Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE C05 - CONVERTIBLE FOLDING ROOF
DD0 - ELECTROCHROMIC MIRRORS: INSIDE REARVIEW&LEFT OUTSIDE REARVIEW DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL E2C - ORDER TO DELIVERY - EXPEDITE
FE3 - SPORT SUSPENSION FE9 - 50-STATE EMISSIONS
FFS - FUEL SYSTEM GMX215-GMX245 PULL-AHEAD G90 - REAR AXLE-3.15 RATIO
G92 - AXLE: 3:15 PERFORMANCE RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF7 - FEDERAL EMISSION SYSTEM NLEV
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT
QF5 - POLISHED ALUMINUM WHEEL R9Z - POMS EXPEDITE - SOLD ORDERS
SLL - SOLD ORDERS T82 - TWILIGHT SENTINEL
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U1S - CD 12 DISC CHANGER, REMOTE
U52 - ELECTRONIC INSTRUMENTATION U75 - POWER RADIO ANTENNA
VDC - VEHICLE INFORMATION CD VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR Z51 - PERFORMANCE HANDLING PACKAGE: (INCLUDES STIFFER SPRINGS AND STABILIZER BARS)
1SB - 1SB PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * ELECTROCHROMIC MIRRORS:INSIDE REARVIEW&LEFT OUTSIDE REARVIEW * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN * TWILIGHT SENTINEL * HEAD UP DISPLAY 1SZ - PREFERRED EQUIPMENT SAVINGS
41T - T0P-BLACK 41U - BLACK
70I - TORCH RED INTERIOR TRIM 703 - TORCH RED SEATING TRIM
Old Jan 22, 2006 | 01:05 PM
denali's Avatar
denali
VEHICLE INFORMATION
PO BOX 218
(731) 772-9082
CLAIM HISTORY
VEHICLE BUILD
OPTION CODES
People like spongevette are what makes this forum the best. Thanks again!
Old Jan 22, 2006 | 07:25 PM
Flatlander's Avatar
Flatlander
Sponge Vette, could you run one more?
1G1YY12S325115271
Old Jan 22, 2006 | 07:33 PM
Sponge Vette
1G1YY12S325115271
VEHICLE INFORMATION
Merchandising Model : 1YY37 -2002 CORVETTE Z06 Warranty Start Date : 01/09/2002
Delivering Dealer : GROSSINGER CHEVROLET, INC.
151 EAST LAKE COOK ROAD
PALATINE , IL 60074-9375
(847) 359-7700
Open Recall Notice:
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM 07/26/2004
CLAIM HISTORY
12/04/2001 A15271 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1614 kg (3559 lb) Order Number : DRWJH6
Build Date : 12/04/2001 Build Plant : 125Y
OPTION CODES
AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE4 - RIDE & HANDLING SUSPENSION SYSTEM
FE9 - 50-STATE LOW EMISSION VEHICLE GU6 - REAR AXLE 3.42 RATIO
IP4 - TRIM INTERIOR DESIGN - AR9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS6 - 5.7L LITER SFI V8 - 405HP
MN6 - 6-SPEED MANUAL TRANSMISSION M12 - 6-SPEED MANUAL TRANSMISSION WITH OVERDRIVE
NF7 - FEDERAL EMISSION SYSTEM NLEV NK4 - LEATHER WRAPPED STEERING WHEEL
P12 - CAST ALUMINUM WHEEL R9Z - POMS EXPEDITE - SOLD ORDERS
SLL - SOLD ORDERS UN0 - AM/FM STEREO W/CD PLAYER
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
U73 - FIXED MAST ANTENNA VM3 - CONSUMER INFORMATION LABEL
V49 - LICENSE PLATE FRAME V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XFW - FRONT TIRE-P265/40R17 YFU - REAR TIRE-P295/35R18
1SA - CORVETTE Z06 BASE EQUIPMENT GROUP 19I - BLACK INTERIOR TRIM
194 - Z06 INTERIOR - BLACK 21U - ELECTRON BLUE METALLIC
Old Jan 22, 2006 | 07:47 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Sponge, can you hook up another brother ?
If you dont, Ill understand because im sure they'll never stop
thanks
Phil
1G1YY32G9Y5123150
Old Jan 22, 2006 | 08:26 PM
Sponge Vette
thanks
Phil
1G1YY32G9Y5123150
VEHICLE INFORMATION
Merchandising Model : 1YY67 -2000 CORVETTE CONVERTIBLE Warranty Start Date : 03/29/2000
Delivering Dealer : MEYER CHEVROLET, INC.
PO BOX 790147
MIDDLE VILLAGE , NY 11379-0147
(718) 821-7650
CLAIM HISTORY
10/11/2004 149937 # V1144 - 04006 - INSTALL HARNESS KIT, REPROGRAM AND PERFORM FUNCTIO 14894 miles
02/25/2004 137345 # J1307 - PISTON, ROD AND/OR RINGS - ONE CYL - BOTH BANKS - REPLACE 12630 miles
10/09/2002 111639 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 7920 miles
10/09/2002 111639 # E0721 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - LEFT - REPLACE 7920 miles
10/09/2002 111639 # E0724 - SENSOR, LOW TIRE PRESSURE WARNING - REAR - RIGHT - REPLACE 7920 miles
10/09/2002 111639 # E0725 - SENSOR, LOW TIRE PRESSURE WARNING - REAR - LEFT - REPLACE 7920 miles
05/20/2002 088580 # N2360 - SWITCH - CLUTCH START - REPLACE 7592 miles
10/30/2000 154108 # E0721 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - LEFT - REPLACE 1816 miles
05/09/2000 149057 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 280 miles
04/26/2000 148628 # J0510 - HEAD, CYLINDER - RIGHT BANK - REPLACE 280 miles
04/26/2000 148628 # Z7903 - 3-DAY COURTESY TRANSPORTATION 280 miles
04/26/2000 148628 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 280 miles
04/26/2000 148628 # J4640 - MOTOR ASSEMBLY, STARTER - REPLACE 280 miles
04/25/2000 265425 # Z8016 - ROADSIDE GONE ON ARRIVAL 280 miles
04/14/2000 148329 # J9995 - CUSTOMER CONCERN NOT DUPLICATED 230 miles
03/10/2000 523150 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1683 kg (3711 lb) Order Number : CGKWV7
Build Date : 03/10/2000 Build Plant : 1Y5Y - BOWLING GREEN
OPTION CODES
AG2 - SIX-WAY POWER PASSENGER SEAT AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS
AQ9 - SEAT FRT BUCKET, PASS, DRIVER BGR
B34 - COLOR-KEYED FRONT FLOOR MATS -CARPETED B84 - BODY SIDE MOLDINGS
CJ2 C05
DL5 - ROADSIDE SERVICE INFORMATION DECAL DL8 - HEATED REARVIEW MIRRORS
FE1 - SUSPENSION SYSTEM-SOFT RIDE F45
GU6 - REAR AXLE 3.42 RATIO IL3
JL4 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 LS1
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
NC1 - CALIFORNIA EMISSIONS LEV NG1
NK4 - LEATHER WRAPPED STEERING WHEEL QG1
R9Z - CONTROL-SALES ITEM NO. 100 T96 - FOG LAMPS
UL0 - AM/FM STEREO CASSETTE RADIO UV6
UZ6 U1S
U52 - ELECTRONIC INSTRUMENTATION U75 - POWER ANTENNA
VL7 - NEW YORK - STANDARD 5 MPH BUMPER IMPACT V49
YGH 1SA - OPTION PACKAGE 01
41T - BLACK CONVERTIBLE TOP 86U
92I - MED GRAY INTERIOR TRIM 923
for some of the options in code only, click HERE to see what they are.
Old Jan 23, 2006 | 10:47 AM
phils C5 vette
Cool Dude, thanks
Old Jan 23, 2006 | 12:55 PM
Vetten Vayo's Avatar
Vetten Vayo
Corvette Museum. Just give your VIN #....... It will cost you I think.
Old Jan 25, 2006 | 05:36 PM
C5forFun's Avatar
C5forFun
Default codes
thanks
Phil
1G1YY32G9Y5123150
Me too, me too, please.
1G1YY22G915116604
To Build date
Old Jan 25, 2006 | 06:58 PM
shannanl's Avatar
shannanl
Sponge, if you go to the forum cruise in then I think about 200 guys (including me) owe you a beer. I hope you drink beer!
Old Jan 25, 2006 | 07:18 PM
zipduda's Avatar
zipduda
Hate to be a pain....but can you do mine please.....
1G1YY22G5V5106688 thanks so much!
Old Jan 25, 2006 | 07:23 PM
Cpe04's Avatar
Cpe04
If it's not too much trouble,1G1YY22G045132484
