Got Juice?
Old Jan 22, 2006 | 12:48 AM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
Default Got Juice?
Decided to do one more perf mod. I always swore I would never do juice but
the kits are so well designed now I feel comfortable going this route. I went
with the 125 dry shot Pro kit from Nitrous Direct. Its an inexpensive way to
add some nice "on demand" power! I screwed up and got a 15lbs tank, I've
ordered a 10lbs tank which fits neatly in the rear storage compartment for
stealth. Planning to put this baby to use at the CI drag races!
I'll post pics after the install;
Old Jan 22, 2006 | 03:16 AM
Halfway's Avatar
Halfway
St. Jude Donor '06
Too dangerous for me. I love my car too much!
Would be like injecting steriods into myself. Great results, but dangerous.
Old Jan 22, 2006 | 06:06 AM
Shane_S's Avatar
Shane_S
Nitrous is like a hot chick with an STD. You want to hit it but you're scared of the consequences.
Shane
Old Jan 22, 2006 | 07:00 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Congrats and hope to see ya' in Bowling Green!
Old Jan 22, 2006 | 07:54 AM
spdislife's Avatar
spdislife
Shane
Great analogy
Old Jan 22, 2006 | 08:56 AM
Vetteran's Avatar
Vetteran
Shane
That is a good analogy and I used to feel that way. But I have spoke to
several folks on the subject. With the quality and control you get today
your very unlikely to have any problems. Especially when you go with a
low shot like 100 and dry. The thrill factor has overuled my fears, I'm
going for it!
Old Jan 22, 2006 | 09:09 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
going for it!
Go for it - great fun.
Old Jan 22, 2006 | 02:41 PM
Vetteran's Avatar
Vetteran
Same here Jim! I've got my reservations made!
Old Jan 22, 2006 | 02:47 PM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
I hope this isn't a dumb question, but what does this do to your warrantee?
Old Jan 22, 2006 | 02:50 PM
Good luck with the install. Your car should really be a beast after putting that on.
Old Jan 22, 2006 | 03:31 PM
Vetteran's Avatar
Vetteran
I kissed the engine warrantee goodbuy when I had the cam put in. Other
than that, nothing (I hope)!
Old Jan 22, 2006 | 03:36 PM
Vetteran's Avatar
Vetteran
Thanks Jack! I looking for more pull after launch. I'm sure this will make a
nice contribution! Are you going to the CI?
Old Jan 22, 2006 | 03:49 PM
vettedevil's Avatar
vettedevil
I have had the juice for about 3 years now with a 75 wet shot and no problems thanks to all the safety equipment such as a window switch & fuel pressure safty switch. but I would expect to replace your clutch soon with the 100 shot.
Old Jan 22, 2006 | 03:57 PM
troy144's Avatar
troy144
Shane
Old Jan 22, 2006 | 04:31 PM
Vetteran's Avatar
Vetteran
Did that when I added h/c. Put in a Luk Pro Gold. From what I've read, it
should hold up to the n2o.... We'll see!
Old Jan 22, 2006 | 05:02 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I am running a NOS Dry system on my car for a 100 shot and these cars are thrusting for the juice. I was skeptical too, but I haven't had any real problems and when I get the tune with my heads and cam set up, I am looking at a 500 rwhp car with the 100 shot. Warranty? Never had one and as for stealth...nope, I put my 15 lbs in back so the nozzle is between the seats...I love it!
Have fun with the install and using it when it is done.
Old Jan 22, 2006 | 08:31 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
Congrats my friend, u'll love it... i too am debating doing nitrous on my motor, but a lot of my friends are telling me not too... im already at ~500+rwhp, which is plenty at that... a cool 100 shot from TNT kit, im up at 600/650 @ wheels...
as a side note, why did u go with the dry kit? usually, a wet is safer... just wondering?
at any rate, enjoy that nitrous!!! your going to love that added hp!
Aj
To Got Juice?
Old Jan 23, 2006 | 12:46 AM
Vetteran's Avatar
Vetteran
Aj
Hey Aj,
Two reasons I went with the dry;
1) From everything I've read and folks I've talked to, Dry is safer;
Originally Posted by Robert56
Even if you have a noid leak on a dry hit sitting, nothing is going to happen. Think about it, throttle is closed and n2o will just go out the filter to atmosphere. why would your friend think this fallacy would be a dry only thing? So much misinformation concerning dry hits, out there. Actually if this was going to be an issue, it would likely be more a wet thing. Wet nozzles are after the throttle, thus a sticking open or leaking n2o noid could (very unlikely) stir up fuel vapors and then when starting boom. Blown Z06 had it right you have a better chance of a shark bitting you in the azz...
Robert
B) Dry comes on a little softer than wet. That suits me since I'm mostly
stock in the backend except for the output shaft. And I can alway covert
to wet if I take the notion!
Old Jan 23, 2006 | 02:18 AM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
I am going with a dry kit too, I don't have the big numbers you guys do, mostly stock here, would like to break into the high 7's in the 1/8, I think this will do it quite safely.
Here is some panels I had made up to replace the ashtray, not sure which ones I am going with still tweaking the designs.
Old Jan 23, 2006 | 07:49 AM
Blow Torch's Avatar
Blow Torch
DANG B99, those panels are SHARP!!
