LS6 intake and coolant tube conversion kit?
Old Jan 23, 2006 | 02:04 PM
freemanjc's Avatar
freemanjc
Default LS6 intake and coolant tube conversion kit?
Does anybody know where I can go to (ONE) website and order the complete (LS6 intake and coolant tube conversion kit) for a 98 C5.
R/
Julius
Old Jan 23, 2006 | 02:07 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I think I know what you are talking about...the alumiun tubing that runs under your LS1 intake Manifold is exachanged for two bypass tubes? If so, it is a GM part, so I would try gmpartsdirect.com
Micah
Old Jan 23, 2006 | 03:39 PM
99vettewsnc's Avatar
99vettewsnc
Check out the following link to SLP's website. Appears they sell everything you need for 399.99 plus shipping. This is the best price I have found for a new LS6 intake.
http://www.slponline.com/view_produc...39&BIG=30039-1
Old Jan 23, 2006 | 03:47 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
However, you can find this intake used for a great deal less and buy the collant lines separate. I see them going with low miles for $300.
Micah
Old Jan 23, 2006 | 04:23 PM
freemanjc's Avatar
freemanjc
Thanks to you both! I greatly appreciate your help!
R/
Freeman
Old Jan 23, 2006 | 08:00 PM
Gary French's Avatar
Gary French
Default Intake
Micah
I have an 03 with vararam and corsa exhaust--would this be the best intake to put on for the money ?
Old Jan 23, 2006 | 08:15 PM
jessejay356's Avatar
jessejay356
03's would already have an LS6 intake...
Old Jan 23, 2006 | 10:37 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Old Jan 23, 2006 | 10:40 PM
Jim Taylor's Avatar
Jim Taylor
You know you can just cut a channel in the fins on the bottom of the LS6 intake and reuse your LS1 coolant pipe. It's not going to affect the performance of the intake, and it'll save you $40-$50.
Old Jan 23, 2006 | 10:45 PM
Joevette99's Avatar
Joevette99
R/
Julius
Fred Bean Chevrolet has the items at good prices. I did the swap two weeks ago. Took three hours worth of work, taking my time. Print out LS1TECh forum instructions to make it simple.
Old Jan 23, 2006 | 10:47 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
That SLP link is the best price I have seen on that setup.
Old Jan 24, 2006 | 04:23 AM
Cole's Avatar
Cole
R/
Julius
Any dealer can provide the bypass coolant parts you need. They are pretty cheap. I also suggest that you pick up some manifold bolts. I had a few that really ddin't tighten down well and I had to go back at them a few days later after I picked up the parts. Also, I put an LS6 manifold on my 2000 a year and a half ago. Last week, a member reported that using an LS2 manifold from a GMC 6 liter truck actually produced better results. Do a search and recover the thread. You can get an LS2 manifold from a salvage yard for !100 or so according to that thread.
I wish I could define wether the KS6 manifold helped, but I did several things all together and did not get a separate dyno run, or even SOP run with just the manifold.
To LS6 intake and coolant tube conversion kit?
