installed hurst shifter
Old Jan 23, 2006 | 08:02 PM
grunz95's Avatar
grunz95
Default installed hurst shifter
I installed my new Hurst Shifter this past Saturday, the question I have is why is the shifter so stiff? Is that normal?
Gary
Old Jan 23, 2006 | 08:28 PM
testpros's Avatar
testpros
It was to stiff for me as well. I put in the lightest springs and now it's great (except for the rattle at higher RPM's).
Old Jan 23, 2006 | 11:27 PM
DirteeDave's Avatar
DirteeDave
Just takes some getting used to. Won't be long before you don't even notice.
Old Jan 24, 2006 | 06:36 AM
Dark-Knight's Avatar
Dark-Knight
Yep, after market shifters are typically stiffer and tend to loosen some with use.
Old Jan 24, 2006 | 06:39 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
Make sure you have the lightest springs in.
Old Jan 24, 2006 | 07:57 AM
CUlookin's Avatar
CUlookin
I put in the lightest springs and the side to side tension was perfect... Damn thing rattles like crazy at high RPM's so I've opted to change it out for the C6 Z06 shifter!
Old Jan 24, 2006 | 01:40 PM
Drop Top's Avatar
Drop Top
There was a thread about shifter rattle some time ago. The answer is to put a hole in a rubber pipe cap or half of tennis ball and put the shifter through it. Then cover it with the boot. I did this with my Hurst install and it works great. Find the thread.
To installed hurst shifter
