3 inch catback vs 2.5 inch catback
Old Jan 24, 2006 | 12:55 AM
STEEL's Avatar
STEEL
Default 3 inch catback vs 2.5 inch catback
I just received my LG pro motorsport long tube headers, and was inspecting them and saw that the pipes are 3 inches thick and my corsa indys are 2.5 inches. So my question is how much if any hp would I gain if any from going to a 3 inch catback, like the GHLs. What is the stock midpipes and stock catback sizes? Just thought I would throw it out there since it seems that going from 3-2.5 may cause the exhaust to be turbulent.
Old Jan 24, 2006 | 06:44 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
Old Jan 24, 2006 | 08:09 AM
CUlookin's Avatar
CUlookin
Old Jan 24, 2006 | 01:44 PM
STEEL's Avatar
STEEL
anyone?
Old Jan 24, 2006 | 07:59 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
2 3/4"...no gain unless you are pushing a lot of air...more than just headers...
Peace
Willfulone
__________________
..................Click for
Old Jan 24, 2006 | 08:00 PM
mitch.smith's Avatar
mitch.smith
Old Jan 24, 2006 | 08:53 PM
turboc5's Avatar
turboc5
The exhaust cools as it moves rearword, so takes up less space (volume). 1500* or so up front and 200-300* out back. Cool contracts, heat expands. so the optimal size for the rear is 2.5 since the exhaust has less volume. If your worried about turblance have a welder install a 3" to 2.5" reducer cone.
Old Jan 25, 2006 | 01:12 AM
STEEL's Avatar
STEEL
I never thought of it that way, so will a 3 in catback reduce horsepower or im guessing it will just not matter much.
Old Jan 25, 2006 | 01:15 AM
FAsnakes's Avatar
FAsnakes
Veteran: Marine Corps
Old Jan 25, 2006 | 06:36 PM
turboc5's Avatar
turboc5
By cat back do you mean the mid secton or the rear muffler section? I believe all mid sections that use stock cats are 2.5". As far as 3" muffler section, I couldn't see you loosing power. But you probaly won't gain much eather. Unless its a large cid motor of forced induction. As far as a 3" mid section, its "usally" worth 5-10hp depending on the car.
Old Jan 28, 2006 | 02:02 AM
STEEL's Avatar
STEEL
yea I guess your right I should stop worrying about losing a horespower.
Old Jan 28, 2006 | 02:09 AM
NSTG8R's Avatar
NSTG8R
only big cube motors benefit from 3" full ..
To 3 inch catback vs 2.5 inch catback
