Pegged oil gauge
Old Jan 24, 2006 | 08:58 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default Pegged oil gauge
Oil gauge pegged out yesterday.. no other problems noted..
possible problem??
Old Jan 24, 2006 | 09:02 AM
RubberBill's Avatar
RubberBill
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
possible problem??
Wow! I read three of these from different people on this forum just yesterday. Sounds like a very common problem but easy to fix if you like to remove the intake manifold. Do a search and you'll find a very good detailed procedure.
Old Jan 24, 2006 | 09:14 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Probably the oil pressure sensor (about $55 bucks) and I am willing to bet on it.
The sensor is located behind the air intake manifold and isn't to hard to do, just a little patience.
If you need anything else, let me know.
Micah
Old Jan 24, 2006 | 09:46 AM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
Yep, oil pressure sensor... Changed mine this weekend... Never work on cars and me and another forum member, pyro5o did it in about 3 hours...
Can find instructions here on the forum...
Good luck grumpy...
Jason
Old Jan 24, 2006 | 10:00 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
DUPE
Inexpensive part...ran mine for a month or more before getting Bob at Dragon's Breath Performance to replace it.
Old Jan 24, 2006 | 10:02 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Yep! Bad sensor....
Yesterday's post.....http://forums.corvetteforum.com/show...5&forum_id=103
Old Jan 24, 2006 | 10:03 AM
Rob Petyo's Avatar
Rob Petyo
In before the lock!
Old Jan 24, 2006 | 10:08 AM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
Originally Posted by 98Pace97Coupe
Old Jan 24, 2006 | 10:09 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Micah
Old Jan 24, 2006 | 10:26 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Damn Oilsensordemic Flue.............
Local guys just called me this weekend about his!
Old Jan 24, 2006 | 11:19 AM
pewter99's Avatar
pewter99
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
ever get to C5 Tech??
Old Jan 24, 2006 | 01:54 PM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
Grumpy,
The part that I got was not AC Delco, it was GP Sorensen and is called an oil pressure switch. Part #OPS191...
The only other things you will need are a gm fuel line removal tool and a 1 1/16th deep socket. The only other problem was the small vacuum line at the back of the intake that will disconnect when you take out the intake. It is a PITA to reconnect...
Hope this helps...
Jason
P.S.
I did find some great instructions on the forum that showed almost every thing I had to disconnect to get to it... Very good to have...
Old Jan 24, 2006 | 02:09 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
St. Jude Donor '05-'06
Great First we have faulty fuel gauages now faulty oil gauges
Old Jan 24, 2006 | 02:11 PM
BosqueVette98's Avatar
BosqueVette98
Mine went out this past Saturday! Seems to be a fragile part... I haven't fixed mine yet, kind of nervous about doing it myself...
Old Jan 24, 2006 | 03:04 PM
S76HeliPilot's Avatar
S76HeliPilot
Oil Pressure sensor, Kinda like the ones in your 412.
If you can find a disconnect in the harness somewhere accessible you can ohm it out. Probably either open or shorted. Your friendly neighborhood A&Ps can probably help.
Old Jan 24, 2006 | 03:07 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
Are you sure you're qualifed to be our moderator? J/K
Old Jan 24, 2006 | 03:12 PM
Frizzle86's Avatar
Frizzle86
Silly noobs all they do is ask the same question over and over again.
Didn't we go over this recently?!?!
Old Jan 24, 2006 | 03:43 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
me too!! I'm getting seriously worried!!
Old Jan 24, 2006 | 03:57 PM
Grumpy's Avatar
Grumpy
MONARTOR
DUPE
time to get violated.....again
To Pegged oil gauge
