Goodyear Gator Back Belts = quiet
Old Jan 24, 2006 | 10:01 PM
ericdwong's Avatar
ericdwong
Default Goodyear Gator Back Belts = quiet
Something in my engine bay started squeeking, not sure what it was I first started with the belts. I put some belt dressing on the main serp and the squeeking went away. It would come back 5 minutes later. The belt was a Dayco belt a little over a year old. I figured what the heck, I replaced with a Goodyear Gator Back after searching high and low. For some reason it is a rare belt none of the local parts stores carry. I had to get it from an Autozone 30 miles away near where I work. It is designed to be quieter. I thought, we'll wait and see. I put the Gator Back on, and sure enough it is quiet! We'll see if it lasts, but so far I'm sold on Gator Backs vs the damn Dayco's.
Old Jan 25, 2006 | 01:51 AM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
Those have been the only belts I have put on any of my vehicles in the past several years.
Old Jan 25, 2006 | 02:27 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
My car recently developed a squeal/squeak and its driving me nuts. I sprayed some water on the belt and pullies just to check and the noise went away for 45 seconds and then came back again I eyeballed closely and no pullies seem to wobble or anything I was going to start out with the new belts first thing. What is the part number(s) for the belt(s) did you get? Did you replace both the belts?
Old Jan 25, 2006 | 09:34 AM
ericdwong's Avatar
ericdwong
I replaced only one of the belts. The main one. I dont have the specific part number but it is something like 6040802...
Old Jan 25, 2006 | 10:48 AM
Downtown's Avatar
Downtown
Those gatorbacks are great. I bought mine from Autozone about a year ago and they are quiet.
Old Jan 25, 2006 | 03:03 PM
Stickman81's Avatar
Stickman81
Autozone prices last time I checked.
BELTS
Goodyear
Gatorback. Alt / PS............4060798.....$26.99
Gatorback A/C...................4040420.....$13.99
Kelly Springfield
Alt / PS........798K6.....$19.99
A/C.............420K4.....$8.99
O'Reilly auto parts store -
Gates
Alt / PS.........K060798.....$23.99
A/C..............K040420.....$15.99
Rockauto.com
Gates
Alt / PS...........K060798.....$16.20
A/C................K040420.....$10.67
AC Delco
Alt / PS..........6K798.....$16.98
A/C...............4K420.....$11.08
Old Jan 25, 2006 | 04:19 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
always used on my old 5.0...going to use on the vette as well...
Old Jan 25, 2006 | 05:30 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Good information!!!! Thanks for sharing.
Old Jan 25, 2006 | 06:01 PM
Guess I'll give the Gatorbacks a try when I need to replace mine. Thanks for the part number info.
Old Jan 25, 2006 | 06:09 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Bought my GY gator belts from Summit for my UD pulley.
Old Jan 25, 2006 | 06:27 PM
Fast98's Avatar
Fast98
The goodyear belts are the only ones I use
Old Jan 25, 2006 | 06:40 PM
coast7's Avatar
coast7
FWIW - there is a TSB around that tells a GM tech to replace the idler pulley when a customer complains about a belt squeek. I had a belt-like squeek and replaced both belts...squeek went away...for a while...then it came back. Replaced the idler pulley...squeek went away...hope it stays away this time.
HTH
Old Jan 25, 2006 | 07:06 PM
MAC5's Avatar
MAC5
Make sure you check for correct part numbers. If I recall at least one of the Gatorback belts part numbers change thru the C5 model run. Can't recall what year it was, but if you check the Goodyear site, you'll get the proper belt numbers.
Old Jan 25, 2006 | 07:21 PM
AtHomeSoda's Avatar
AtHomeSoda
Default hummmmmmmmmmm
On the Goodyear site.... only the 99 corvette has the 4060798 all the other years have 4060802 for the main belt. hummmmmmm what is different?
Old Jan 25, 2006 | 07:24 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Yep, I did put those belts on when upgraded the heads.
-Mike
Old Jan 25, 2006 | 07:51 PM
FactoryRaceCar
Well ordered mine through Auto Zone today. They should be here tomorrow. Cost was about $49.xx with tax. Anyone got any instructions on how to change both belts?
Old Jan 25, 2006 | 07:58 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
The last 3 numbers is how many inches the belt is ex.802 is 80.2 in and 798 is just shy of 80 in. anybody correct me if I'm wrong.
To Goodyear Gator Back Belts = quiet
Old Jan 25, 2006 | 09:00 PM
Stickman81's Avatar
Stickman81
No specific instructions but -
It maybe easier to change the A/C belt from the bottom side of the car. There is not much room to take the tension off the pulley to get the belt on and off. I did both belts from the top in about 45 minutes, taking my time and making sure the belts were on the balancer.
Old Jan 25, 2006 | 09:58 PM
MAC5's Avatar
MAC5
Probably a pulley diameter dimension, alternator or p/s
Old Jan 25, 2006 | 10:11 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Just put a 15 mm socket on the tensioner and tug releasing the tension. Bell will come right off.
