So I got a Leakdown test done.....
Jan 25, 2006 | 12:57 AM
And I didnt have compression on 4 cylinders in my 98 C5.
Now I have to get new cylinder heads, gasket set and intake valves.
Cost with labor is $1912 at $65/hr for labor.
Any idea where I might be able to get the parts for cheaper online or some store??
The parts in the estimate seem cheap and would come with a warrenty but I would at least like to see if I have any options before I lay 2 large down.
Jan 25, 2006 | 08:33 AM
your getting very close to a new short block ls2 or you can find on ebay a low milege ls1 engine. i would seriously consider this route before just rebuilding a bone stock engine.
Jan 25, 2006 | 09:13 AM
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
I think for 2000 you can rationalize just about any new set of heads.
I would have your car towed to an aftermarket company, and have them install a set of aftermarket heads, for only pennies more.
Chris
Jan 25, 2006 | 10:03 AM
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Check out the for sale section on the forum. There are always heads and cams for sale. Good luck with the rebuild.
St. Jude Donor '06
Chris
Jan 25, 2006 | 10:07 AM
Sounds like a good reason to up the HP/TQ!!! Throw in a few more goodies while you're at it!
Jan 25, 2006 | 10:27 AM
You should be able to get a used set of LS1 heads for about $250 that are in excellent condition, then a gasket and new bolts for $50. Then do it yourself install would be pretty easy......if it is just the heads that are the problem...
Jan 25, 2006 | 10:34 AM
Quote:
And he would have the same problem with heads and valves. I doubt a long block would cut his expense because of installation..
Jan 25, 2006 | 11:06 AM
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
What makes them think its the heads that are a problem. Is it one bank that has no compression? Just want to make sure the problem is not in the bottom end.
Jan 25, 2006 | 12:27 PM
I see you are from Baton Rouge. Have you talked to Jason at Thunder Racing or Allen at Futral Motor Sports? If not talk to them ASAP. Jimmy
Jan 25, 2006 | 02:06 PM
CI 3-5-6-7-8 Veteran
What happened to the car to do this? Was it supercharged in a former life?
Jan 26, 2006 | 02:07 AM
Quote:
My understanding of it was that it was the Valves that needed to be replaced and that there was no compression in 4 cylinders and very little in the other 4.
I dont think I have new heads on the invoice just valves and labor???Does that make sense?
Jan 26, 2006 | 02:08 AM
Quote:
Yeah if I go aftermarket then that is where I will take it for sure.
Jan 26, 2006 | 02:09 AM
Quote:
Missed a gear and redlined. Apperently that was enough. It wasnt even for that long but it bent the valves anyways.
Trust me I feel retarded I dont know how I messed it up this bad.
Jan 26, 2006 | 10:04 AM
Gotcha... a mechanical overrev can really **** up a pushrod motor. Did you go 3rd back into 2nd instead of 4th?
When I'm road racing (HPDE) and have to put it in 5th I make the shift very slowly and deliberately... it'd suck to jam it back in 3td at 145 mph
