Another Lowering ???
Old Jan 25, 2006 | 06:23 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Default Another Lowering ???
I just lowered mine on the stock bolts. I could only turn the front bolts 5 full turns. Thats only 10mm which I think is only about 1/2 inch. For those of you that lowered on the stock bolts, how many turns did you get the front bolts to turn?
jeff
Old Jan 25, 2006 | 08:10 PM
troy144's Avatar
troy144
Old Jan 25, 2006 | 08:17 PM
3318C5's Avatar
3318C5
Maybe your car was already a little low to begin with. I am not sure of how "many turns it takes". However if you are down to the bottom, that is it. If want more, you will need longer bolts for the back and to cut the front bushings.
Old Jan 25, 2006 | 08:57 PM
testpros's Avatar
testpros
Mine turned only about 5 turns as well (and was not lowered prior to me taking ownership). Only lowered it about 3/4". I guess it's time to cut the bushing.
Old Jan 25, 2006 | 09:02 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
I don't remember exactly how many turns, but I think it was a couple more than 5.
Old Jan 25, 2006 | 09:55 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Cut the bushing and you can go way lower
Old Jan 25, 2006 | 09:56 PM
JeffC5's Avatar
JeffC5
Thanks for the replies. I'll drive it for a couple hundred miles and make sure it settles as much as it's going to. I don't really want to cut the bushings. I scrape everything as it is. lol
jeff
To Another Lowering ???
