Airbank System
What do I need to replace?
Jim in Port Saint Lucie, FL
THanks in advance
Jim
I ran my car cross country with that code. Really the air system only operates for about the first few minutes once the car has been started. (From what I was told on here) I finally had it tuned out. Don't loose sleep over it.
Micah
Though not sure if true for your 1998, but had read that the engine computer might continue to 'test' the AIR injection system to try and resolve the error.
This could result in additional battery drain, but worse is it could burn-out the AIR pump, a unnecessary expense.
Pull the codes, to be sure what it is and at least consider pulling the fuse for the pump until it can be fixed, just in case.
BTW, if it is the driver side check-valve, it's the black thing sticking-up above and outboard of the valve cover in the shinny exhaust pipe and is a piece of cake to replace (and only about $30 for the part at any dealer/ACDelco parts place). Just requires a couple of big wrenches or adjustable wrenches.
Further, the AIR injection system helps heat-up the Catalytic Converters and possibly the O2 sensors, which seem to help the LS1 move into 'closed loop' more quickly and helps with both fuel economy as well as performance.
Additionally, if the check-valve is stuck open, it can adversly effect vacume hoses and the other side of the engine, so it's not really worth just ignoring it.
BTW, if it turns out to be the 'passenger side' check-valve, that one's a pain, it's behind the intake under the cowl-vent, but I have read still doable without intake removal.
P.S. experience based on 2000 TransAm 6-speed with LS1 engine.
Are you sure about the value?
Oops... just noticed the original subject of the post, you meant P1416, "secondary Air Injection (AIR) System Bank 2...
In otherwords, the one behind the intake manifold...
And the 2000 manual does say remove intake to get at it, but I'm sure I read someone doing it without removal -- and unfortunately, the Corvette isn't made by Pontiac, cause the passenger side check valve on our 2000 TransAm was right above the exhaust manifold and a piece-of-cake.
However, all the other things I said above may still apply, so be careful.
One other thought -- if you do the 'bank 2' check-valve, also do the bank 1 (driver side) as they were both bad on our 2000 TransAm.
