Exhaust...............
Old Jan 29, 2006 | 07:31 PM
MedChoice Tony's Avatar
MedChoice Tony
Default Exhaust...............
Does the Corsa Pace Car Exhaust sound like a motor boat at idle with a stock setup? Also, would an X-pipe be needed? Thanks in advance..
Tony
Old Jan 29, 2006 | 07:34 PM
rgtkst's Avatar
rgtkst
YES. and yes if you want it not too. look at the x pipe threads here.
Old Jan 29, 2006 | 09:23 PM
MJD's Avatar
MJD
Mine does sound a little bit like a motor boat. You will also get popping on deceleration. I don't know it this would work but you could pull you midsection and open up the holes in the H-pipe. The are fairly small. Doing this would save you the cost of an X-pipe. While its down you could gut the pup cats too. Hopefully someone who has done this will chime in and tell you how much it helps. I'm going to give it a shot this spring.
Old Jan 29, 2006 | 09:25 PM
jrose7004's Avatar
jrose7004
My Corsa Pace Car system with X-Pipe doesn't have a motorboat sound.
Old Jan 29, 2006 | 09:35 PM
bb609's Avatar
bb609
I like mine but it took a bit getting used to. It's different!
Old Jan 29, 2006 | 11:09 PM
MedChoice Tony
Thanks for the information....maybe I'll go with the Ti's....
To Exhaust...............
