I have a 2000 with the same exhaust. Also had the same problem as you, as well as a lot of resonance in 6th gear. Installed a Bassani X-pipe and things are so much more livable. Really reduced the resonance and the popping, while still there, has been reduced significantly.
I got the same set up much better and the x pipe gives you a few more hp.
