Tires during storage.
Old Feb 1, 2006 | 10:02 PM
bradleyls103's Avatar
bradleyls103
Default Tires during storage.
I have an 03 with stock rims and tires, stored in a pullbarn with cement floors, somtimes heated.
Are flat spots a thing of the past, or do I need to move my car around in the winter? It sets for about 5 months, do I really need to move it around?
I just started it for the first time since October and it started right up. Also is there a build in battery kill or somthing. I thought i herd that once it goes to10 volts or somthing the car cuts everything off so it can't drain anymore. Is this true?
Old Feb 1, 2006 | 11:13 PM
rws.1's Avatar
rws.1
flatspots are a thing of the past... especially if you are using runflats which have very stiff sidewalls.
What you should do for winter storage is to inflate your tires to the mazimum pressure stated on the sidewalls. This will eliminate any flat spot issues.
Remember to re-adjust the pressure to the correct pressure in the spring.
Old Feb 2, 2006 | 12:14 AM
troy144's Avatar
troy144
Old Feb 2, 2006 | 12:22 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
I would counter that flat spotting can still occur even with run-flats (happened on our 94 with oem goodyear GSC's when sitting for 2+/- months).
However, thick-cardboard or carpeting placed under the tires, with just normal tire pressure (33 in our 94, 32 in our 2000) virtually elimates our flat-spotting (does on both ours -- my speculation is this works because it insulates the constant low temperature cement from the variable air/tire temperature).
Regarding your question about a 'battery kill' feature, don't know about your 2003, but doesn't exist in our 2000, and based on so many reports of dead batteries and lost memory, I'd say it may not be built into the C5's, although there are after-market products that can do it.
Old Feb 2, 2006 | 05:54 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Right after I got my 2001 coupe, I called GoodYear's tech help number, and told them I was storing the car for the upcoming winter and asked for advice. Their person said to put something under the tires to get them off the cold concrete and pump them up to 40 lbs. of air pressure.
I found some old carpet, cut it into 12" squares, put 2 squares under each tire, pump them up to 40 lbs, and that's it. Been doing it for the last 4 winters....
To Tires during storage.
