I got my invisicord for my V1, went to install it and i push the connectors into the harness and they just slide right back out, is there something i am not doing or some other step i should be doing to keep these things plugged in. HELP,
Each of the "holes" in the factory connector have 4 sides, try pushing the connectors into a different are of the port. Maybe even push up the factory wires (to get them to move up slightly opening a gap inside the harness) and push the connectors under them. The connectors should go all the way in up to the larger diameter collar.
well i got the pin in until the connector but they are just loosely in there. and if you move them a bit it looses connection and doesn't seem to have much more room to push in.
The cord now has a ground black shrink tube, and a yellow +12v shrink tube, the cord from this picture had directions pertaining to the green/red wire colors.
