Lately I have been feeling a change in my car. Everyone tells me that it drives the same but I am having serious doubts. Here is what I feel:
For instance, previously my car used to be at 1800 RPMs in the 6th gear going at 80, but now it is at 1400 RPMs at the same speed. And this is true at all the speeds - for the same speed now, it goes at lower RPMs.
Now I have 2 questions:
1. Is this possible that it actually changed or I am having unnecessary doubts.
2. If its possible and it did happen, does this mean the car got better or worse?
3. What could've caused it?
unless someone stole your rearend and replaced it with another. this is not possible. are you driving your car this is not possible. if you said it now runs at a higher rpm. maybe a clutch slipping. but lower??? no way maybe your tach is going wacky, or change the spedometer back to miles per hour, not kilometers per hour. that mught help. do you notice people flying by you looking at you oddly?????
Changing brake rotors could also cause this. Thing is you'd have to go to a smaller diameter roter or a rotor the same diameter but ligher to get this kind of change. If you went to a lighter rotor with larger diameter you would have to push the engine slightly harder to get the same power to the wheels. Even though the rotors might be lighter the added diameter increses the moment of inertia (inertial resistance to rotation) and in turn require the engine to push harder at the same speed (and actually slightly decrease RWHP). This is the same explanation for a tire or wheel change possibly causing the difference.
Ummm....no.
The relationship between RPM and speed is a purely mechanical connection. The equation is:
Inertia has absolutely nothing to do with. The only way it can change is to alter one of the above variables. A 22% change, however, is huge. Can't be the tire. I'm guessing it's an instrumentation error.
WHAT?????? might take more power to turn a heavier rotor/wheel combo, but deffinately not more rpm. to me this is most likely the diff betweeen miles per hr and killometers per hr in the display. if what used to be x at 60miles per hr. click the display to kilometers per hr and you will slow the rpm by 20-25% because you adjust the speed to reflect the slower kilometer per hr. if you didn't know this you would be buzzing around going slower, and there for the rpm would be slower.
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
I want a little of what you are are smokin cause obviously it is better than mine
