Suggest a clutch
Old Feb 4, 2006 | 10:03 PM
blkonblk_c5's Avatar
blkonblk_c5
Default Suggest a clutch
suggest a clutch for a slightly moded c5 ( intake, exhaust, ect.)
Old Feb 4, 2006 | 10:18 PM
WKMCD's Avatar
WKMCD
LS7 will last you a long time, work great and feel like stock.
Old Feb 4, 2006 | 10:38 PM
blkonblk_c5
thanks any others? I was looking at a luk pro gold good for up to 575hp? or so has anyone used this one?
Old Feb 4, 2006 | 10:59 PM
1badc5GoStrong's Avatar
1badc5GoStrong
Default Z06 Clutch
DTE put Z06 clutch in mine w/440 RWHP AND 439 RWTQ. It is all you need.
Old Feb 5, 2006 | 05:51 AM
Sportsdude's Avatar
Sportsdude
I have C5 Z06 now but when this one need replacing, I will go with the C6 Z06.
Old Feb 5, 2006 | 08:35 AM
1badc5GoStrong
ttt
Old Feb 5, 2006 | 09:04 AM
Dark-Knight's Avatar
Dark-Knight
Old Feb 5, 2006 | 06:07 PM
blkonblk_c5
thanks all the suggestions help and where did you buy yours napa or at a dealer? did you install or did you have it done? was there a large price differnce in parts? my brother is a porsche mechanic but I heard this is a difficult set up. should I have him do it?
Old Feb 5, 2006 | 06:56 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Just make sure you get brand new LS6 Master and Slave at the same time and dont forget to do the drill mod to the slave.
Old Feb 5, 2006 | 07:47 PM
wstory1's Avatar
wstory1
Old Feb 5, 2006 | 10:34 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
If you plan on staying close to stock the C5 Z06 or the C6 Z06 clutch will work fine and also upgrade to the Z06 master and slave at the same time
Old Feb 5, 2006 | 11:49 PM
blkonblk_c5
someone please explain the drill mod in full to me I heard it once before but didn't know what they were talking about.
Old Feb 6, 2006 | 12:30 AM
ls1vette97's Avatar
ls1vette97
please do!
Old Feb 6, 2006 | 12:37 AM
FactoryRaceCar
Here you go!
http://vetteweb.com/tech/vemp_0506_clutch/index2.html
Old Feb 6, 2006 | 06:19 PM
blkonblk_c5
thanks I am very greatful.
Old Feb 6, 2006 | 10:38 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
I'd stay away from the "Z06" or "LS6" clutch. It's comes from the factory in ALL 01-04 C5's or Z06's. LS1 or LS6. There's nothing Z06 specific about it. It's really not all that good.
If you are a "bolt on" car, then I would suggest the new LS7 clutch. It's new.. so not a ton of feedback and no real long term info on it yet. Doesn't look bad though...
If it's a seriously modded car, I would suggest an RPS/Textralia. My Spec 3 has been great to me as well. Spec seems to be a hit or miss though..
steve
Old Feb 6, 2006 | 10:46 PM
gknight's Avatar
gknight
I'm runnin a LUK pro gold and man is it noisy. Works great but sounds like rocks in a can at idle with the clutch out.
To Suggest a clutch
Old Feb 6, 2006 | 10:48 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
If you're not pushing more than stock HP - what's wrong with simple stock?
Old Feb 6, 2006 | 11:09 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
Originally Posted by FactoryRaceCar
That's great but it didn't say what size drill to use. Stupid question maybe but inquiring minds have to know.
Old Feb 6, 2006 | 11:41 PM
FixedRoof's Avatar
FixedRoof
I don't remember the exact size that I have used in the past. Done it 3 times with no problems. Basically, you want it large enough... but not as large as the "ball" on the end. It still has to seal well. Just make it a lil bit bigger than stock. You can kinda get the idea when you have it apart and are looking at the end.
