Transaxle Hop
Old Feb 5, 2006 | 09:06 PM
tchow01's Avatar
tchow01
Default Transaxle Hop
I was reading about "lauching off" and wanted to know why transaxle hop is bad and wheel spin is OK. Can someone explain why this hop is bad and how can it be prevented.
Old Feb 5, 2006 | 09:16 PM
Tino's Avatar
Tino
It is bad because it can fracture the aluminum drive train case re: transmission and diff. How to stop it ... a real topic of discussion and idea's. Some say replace the bushings with polyurethane bushings, some say get rid of the run craps, some say drive train mounts, some say get a Z06 leaf spring, etc ....
Good luck
Tino
Old Feb 5, 2006 | 10:42 PM
y2kcorvettebob's Avatar
y2kcorvettebob
Start off with dumping the Run Flats and the plastic sway bar links
Old Feb 5, 2006 | 11:05 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
a little wheel hop with break the differential clean off teh transmission, and when it does it will shear off the output shaft of the transmission....thus creating a new need for a new transmission AND differential...a cheap fix for under 3k if you do it yourself.
a 400 dollar DTE brace is cheap insurance to ensure that it doesn't happen.
How do i know this can happen? I know.
chris
Old Feb 6, 2006 | 01:25 AM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
On a somewhat related note, what's the best way for me to burn a little rubber without wrecking something in the process? I haven't tried yet, but would like to do it, just once. I have an A4 with the 3.15 axle. I feel a little sheepish even asking such a question, but like I said, I'd like to try it. Just once.
Old Feb 6, 2006 | 05:31 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
just jump on the gas. With an A4 and 3:15 ratio, that's about all you will burn. I little rubber
Old Feb 6, 2006 | 08:32 AM
Stangkiller
like he said just jump on the gas if it starts to bounce GET OUT OF IT! Or you could use a little puddle of water + clorox <if you want lots of smoke> to get it started!
Old Feb 7, 2006 | 01:37 PM
tchow01's Avatar
tchow01
Thanks folks for explaining why this is bad.
Old Feb 7, 2006 | 02:00 PM
NSTG8R's Avatar
NSTG8R
the wheelhop is 10x (+/-) worse on a mn6 verses the a4
To Transaxle Hop
