Replacing TP sensor. Can I replace just one?
Old Feb 6, 2006 | 11:18 AM
Hammie's Avatar
Hammie
Default Replacing TP sensor. Can I replace just one?
I have a dead TPS sensor on the set of wheels I just bought. I'm not interested in replacing all four since no tires need to be taken off so it wouldn't benefit me to do it now. A rep from a tire shop I called said I may need to replace all four at once due to their calibrations. I don't think he's correct, and I'd like to only replace the dead one. Can someone verify if this will work?
Old Feb 6, 2006 | 11:57 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Yes you can replace one, but you will have to relearn all four
Old Feb 6, 2006 | 11:59 AM
Leo the Lion's Avatar
Leo the Lion
Cruise-In II Veteran
Yes one at a time is ok. Retrain that sensor with a strong magnet and your all set.
Hammie's Avatar
Hammie
Thanks. No problem relearning them. I'll replace the other three when I have the tires off next.
To Replacing TP sensor. Can I replace just one?
