[Z06] Question about oil change intervals...
How many miles is it going to be monitoring the oil life, assuming you're using the recommended manufactuers oil?
I have typically changed my oil 3K miles or every 3 months in the past on my Z28.
I limit my Z06 driving to weekends only. My "change oil soon" light came on yesterday.
Any sugestions? Mobil-1 5w-30? Which one?
-Thanks-Goose
-Thanks-Goose
For the last 20 years I have always changed oil in my vehicles at 6,000 miles with non synthetic oils and have NEVER once had an oil related engine malfunction. And those engines always went beyond 100,000 miles before I sold them. Now with my synthetic oiled Corvette I just follow the computer.
In 1966 one of my first jobs was to collect the data that was one of the original looks at "oil life evaluation". Basically, if you drive it long enough to warm the oil to the point the "bad shxt" cooks off, you don't need to change it as often. The additives are depleted based on "this", as well as "dirt" accumulation.
Data Collection: In a fleet of cars, I rode in them and wrote down the oil and anti-freeze thermocouple readings as they were cold-started and driven on different distance "city cycles", and recorded the "cool-down" temps over 24 hours. And, I collected oil samples for chemical and metallurgical analysis. We waited for a February cold spell with below zero weather.
The hard part was laying out the initial "cycle start times" that would let me get the data on ten different cars over the same time period. Data recording has come a long way since then. I guess parkas and "big boots" are no longer mandatory.
P.S. When you start it, then drive it somewhere, until the oil temp. hits at least 180. Your engine will love you for that, and return the favor with longer life.
To each his own, and whatever gives you a warm, fuzzy feeling.
It's fail-safe, and cheap insurance to make you feel good.
But, I can't resist:
It's sorta like "taking care" of your wife/and/or girlfriend on the schedule YOU want,
rather than when SHE needs it.
JUST KIDDING ! ! !
Actually, if you drive somewhat 'spirited' it will be down around 10~15% around the 5000 mile mark.
Corvette C5 Used Oil Analysis Report
Based on this, I personally feel that following the owner's manual requirement to change the oil annual, or whenever indicated by the Oil Life Monitor, whichever is first, is a reasonable approach.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Thanks!
I use 5w30 new car formula Mobil 1, and try and change it between 3 and 4 thousand miles!
and I will usually have to add a quart in between
EBZ0602
EBZ0602
I'd just like to leave things alone, if they're working fine. I will get some Mobil-1 5W-30 then.
-Goose
