Clb
Old Feb 6, 2006 | 10:59 PM
badblackc5's Avatar
badblackc5
Default Clb
How can I tell if my car has the CLB installed already. I got it used with 4066 miles .
Old Feb 6, 2006 | 11:04 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
What year is it and is it a A4 or 6sp.
Plus go to your local dealer and then can tell you if the recall has been done
Old Feb 6, 2006 | 11:06 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Go outside and give the wheel a turn. If it's not locked, you have a successful CLB install.
Old Feb 6, 2006 | 11:08 PM
C5naples's Avatar
C5naples
Old Feb 6, 2006 | 11:12 PM
badblackc5's Avatar
badblackc5
Its an 01 6spd. So if the wheel turns when the car is off it has a clb. If not it needs one?
Old Feb 6, 2006 | 11:19 PM
REW89's Avatar
REW89
On my 99 6 sp I had to give the wheel a few strong back and forth tugs to get the lock to engage. I suggest you do that.
If it does not lock you likely have the clb installed. After I installed my CLB it does not lock at all.
Bob
Old Feb 6, 2006 | 11:22 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
That's the easy way to tell.
Old Feb 7, 2006 | 08:17 AM
love my car's Avatar
love my car
Yup thats it.
Old Feb 7, 2006 | 09:19 AM
dunbindun(tov)'s Avatar
dunbindun(tov)
Definitely. Do a search for "column lock" and you will read all about the problems of not having it. Just do it!
DBD
Old Feb 7, 2006 | 09:43 PM
badblackc5's Avatar
badblackc5
I'm not debating weather I should do it or not. I don't want to do it if its already been done.
Old Feb 7, 2006 | 10:17 PM
WWK888's Avatar
WWK888
So....does your wheel turn with the ignition off?
Old Feb 8, 2006 | 12:10 AM
Cscokd's Avatar
Cscokd
Assuming an MN6 and no error messages, if your steering wheel turns while the ignition key is removed, you can conclude that you have either a CLB or a K Harness AND your column lock motor is disconnected OR the locking ring has been replaced.
The best way to determine what you actually have is to remove the knee bolster under the steering column and inspect the ECL wiring harness. PM me if you need help.
To Clb
