Service Column Lock!!!
Old Feb 7, 2006 | 08:33 PM
bierbelly's Avatar
bierbelly
Default Service Column Lock!!!
Even after the recall! DIC message only, so far. Calling the dealer tomorrow.
Old Feb 7, 2006 | 10:58 PM
rws.1's Avatar
rws.1
bierbelly.....4 stars and you have ignored the most posted topic on the Forum.....???
The overwhelming advice on this topic is FORGET THE DEALER.... buy and install a CLB...Corvettes of Houston or Thunder Racing.
Old Feb 7, 2006 | 11:00 PM
army2000's Avatar
army2000
St. Jude Donor '11
CLB does nothing for a M6
Old Feb 7, 2006 | 11:07 PM
ae1m's Avatar
ae1m
CLB prevents column lock on M6, does nothing for an automatic.
Old Feb 7, 2006 | 11:09 PM
Atascadero_Kid's Avatar
Atascadero_Kid
Excuse me?
Seems like someone wasn't paying attention in class.
A column lock bypass is the ONLY way to keep an M6 from locking up. The recall for the M6 just flashes your PCM so that your fuel pump shuts off if the column lock doesn't unlock. You still get to play roulette with your steering wheel every time you shut down without a CLB on board.
Old Feb 7, 2006 | 11:28 PM
army2000's Avatar
army2000
St. Jude Donor '11
Originally Posted by Atascadero_Kid
Excuse me?
Wooo....hold on to your tail pipes there folks. Lets get this right. On A4's the CL is disabled all together. On M6's the recall shuts off fuel in "the event of a Column Lock". Maybe my terms were a little off, but I didn't just sprout out of the ground yesterday.
BTW, Cool your heels buddy, I'm the the one to be aiming your "throttle" at.
Old Feb 7, 2006 | 11:29 PM
blkonblk_c5's Avatar
blkonblk_c5
Before I was a forum member this happened to me on my 98 m6 and it cost me $1018. I wish I new of corvette forum sooner. buy the bypass. BTW I later did alot of research on this and it all depends on the year and trans. in your vette but the bypass will work for both mn6 and a4.so don't go jumping down each others throats.
Old Feb 7, 2006 | 11:55 PM
Cruisin''s Avatar
Cruisin'
OK, call me silly here, but I'm a new kid in town and need a little 'splanin on this here topic. What exactly does the Column Lock By-pass do & is this something I should be looking into ? How does one know if they might already have one?
2000 M6 and 3:42 rear
Inquiring minds would like to know ...
Oh, and thanks in advance for the education
Old Feb 8, 2006 | 12:20 AM
mrC5er's Avatar
mrC5er
First of all, go to the sticky that's posted in the C5 Tech area.....
The bypass, in plain terms, is a "simulator" of sorts. It replaces and simulates the column lock actuator motor inside the column. It's nothing more that a latching relay with a couple of diodes to maintain current flow in the correct direction depending on the make-break state of the relay. It fools the BCM into thinking it's talking to the actual motor, so that the BCM doesn't get confused and start setting codes that could shut off the fuel. Meanwhile, the actuator motor is still sitting inside the column, but is totally disconnected from any power and BCM signals. If you have the manual trans, and do NOT have a bypass installed, you'll hear the actuator motor every time you turn the ignition key to "Run" or "Off". It's that funny, half-second whirring noise coming from the column. What's actually going on in there is that the motor has a worm-gear drive that "screws" the locking pin up through holes or slots in the lock plate, thus locking the column.
Hope this helps...
Mike
Old Feb 8, 2006 | 01:05 AM
Cscokd's Avatar
Cscokd
sometimes it seems hopeless almost 27,000 views of the sticky and we're still confused
Plzzz Read
Old Feb 8, 2006 | 04:00 AM
WWK888's Avatar
WWK888
Yes your terms were a "little off" which is the reason your post was inaccurate. Big difference between CLB (Column Lock Bypass kit) and Recall. Don't jump on someone for correcting misinformation.
Old Feb 8, 2006 | 07:07 AM
Joe's Eray's Avatar
Joe's Eray
Plzzz Read
Old Feb 8, 2006 | 07:14 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Plzzz Read
Amen................
Old Feb 8, 2006 | 08:28 AM
bierbelly's Avatar
bierbelly
I am a believer in the phrase "if it ain't broke, don't fix it". Now it's broke.
Old Feb 8, 2006 | 08:29 AM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Once again:
1997-2004 MN6 - the CLB is highly recommended as the recall will not prevent column lock
1997-2000 A4 - CLB or recall your option. Just know that some 97-98 models have difficulties accepting the CLB and will cause "Pull key..." messages on a regular basis.
2001-2004 A4 - the factory took care of your problem.
Old Feb 8, 2006 | 08:44 AM
bierbelly's Avatar
bierbelly
Going to the dealer tomorrow, hopefully to clear all codes, and the CLB is on order. I've also ordered the CAGS bypass and a cleaning kit for my Blackwing. Car now has 40K on it, what else will the dealer want to do?
Old Feb 8, 2006 | 09:25 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
On my A4 2000 had the dealer remove the k harness after getting all the pull key B.S., plate is in for lock pin and I'll do the clb to eliminate the actuator from functioning. That'll cover me ..
To Service Column Lock!!!
Old Feb 9, 2006 | 12:02 AM
Atascadero_Kid
They like to perform the 40,000 mile cashectomy.....
Old Feb 9, 2006 | 12:17 AM
Cruisin''s Avatar
Cruisin'
Hope this helps...
Mike
Mike - Thanks for the read! Much appreciated.
Old Feb 9, 2006 | 12:29 AM
edensknight's Avatar
edensknight
