Tire Pressure?
Old Feb 8, 2006 | 11:46 PM
jah13's Avatar
jah13
Default Tire Pressure?
I have a 1998 C5 with RunCrap tires. What is the typical air pressure most commonly used? Should I stick to what is posted on the door sticker? I think the car feels better when I run 35 PSI. What are your thoughts??
Old Feb 8, 2006 | 11:48 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
30 PSI cold all the way around...
Old Feb 8, 2006 | 11:58 PM
poolhustler's Avatar
poolhustler
Old Feb 9, 2006 | 12:02 AM
SLPRC5's Avatar
SLPRC5
If you can get rid of the run craps and get some Kumhos and air up to 30 psi..be happy
Old Feb 9, 2006 | 01:37 AM
edensknight's Avatar
edensknight
Another vote for 30psi cold for longevity and overall daily driving. Enjoy!
Old Feb 9, 2006 | 07:33 AM
mhdi22's Avatar
mhdi22
Old Feb 9, 2006 | 08:41 AM
Tom/99's Avatar
Tom/99
I have been running 31 PSI in the front tires, and 29 PSI in the rear tires.
Old Feb 9, 2006 | 09:07 AM
jrose7004's Avatar
jrose7004
30 psi cold!
Old Feb 9, 2006 | 09:10 AM
rws.1's Avatar
rws.1
30 to 30 psi cold gives me the best overall performance
Old Feb 9, 2006 | 09:20 AM
jackj's Avatar
jackj
If you feel better @ 35 then put that in, But............ the center of the tires will wear out fasssssssssssssssssst.
Old Feb 9, 2006 | 09:21 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I follow the recommendation on the sticker - 30PSI cold. Understand that this is the RECOMMENDED pressures, but the Corvette engineers determined that this pressure was the best compromise of ride, tire wear and traction.
The problem with inflating the tires to 35 psi cold is that as the tire and the air in the tire heats up - the pressure increases even more - probably in the 38 - 40 psi range. That high a pressure will cause an already stiff tire to feel so stiff that you'll seriously and unneccessarily compromise the ride and handling.
Forum Member Evil-Twin adjusts his tire pressure to keep the pressure at 30 psi all the time - hot or cold, and has reported acheiving some incredible mileage out of his tires. He would know - he is a retired GM engineer that worked on the Corvette project, and in my mind, one smart guy!
Old Feb 9, 2006 | 09:32 AM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
Here's a possibly stupid question. Would you happen to know how he does this? Does he get out of the car after the tires are warmed up and adjust the pressure or does he have some remote way of doing this?
Old Feb 9, 2006 | 12:37 PM
blacksedan87
It's not a stupid question DJ. I would think he knows how much the air is going to expand pretty well and adjusts his pressure when he starts out accordingly. He's really a pretty smart guy who will answer sincere questions - if you want to know for sure what he does, send him a PM and tell him for me! His Screen name is Evil-Twin and here's a link to his profile......
http://forums.corvetteforum.com/memb...ster&t=1291829
Old Feb 9, 2006 | 01:04 PM
JMc's Avatar
JMc
I'm curious as to how and why Evil Twin would do this. Seems mighty inconvenient, to start with 30lbs cold, then drive around for a half hour and get out to let some air out of the tires, only to have to re-inflate them to 30lbs again before your next trip out.
I'm wondering if it would make more sense to "split the difference" and leave them at 28 PSI cold, knowing full well that they will hit 30lbs fairly soon after launch and maybe rise to no more than 32 fully hot.
Interesting discussion...
Old Feb 9, 2006 | 02:00 PM
TomT's Avatar
TomT
I started leaving the pressure at 28 cold and they come up to 30 in a few miles. Driving at 30 psi when warm makes the most sense to me. If you inflate to 30 cold, in the summer, they get to 35 hot in a hurry, and then would be overinflated. Thereby causing excessive center of tire wear. That's my story and I'm stcking by it.
Old Feb 9, 2006 | 02:45 PM
RTSVET's Avatar
RTSVET
I found that around 28 cold in the winter and 26.5 to 27 summer are just enough to keep the tpms from going off so after a few miles the tires are at around 31 summer seems to be about as low as i can go cold in the summer.
Old Feb 9, 2006 | 05:28 PM
Rapidity's Avatar
Rapidity
I can never get all 4 of mine to say the same thing. Even if they all say the same when they are cold... 10 seconds down the road I've got 2psi more FR than FL. It kills me... I think it is giving me an obsessive compulsive disorder.
To Tire Pressure?
Old Feb 12, 2006 | 09:10 AM
604_c5's Avatar
604_c5
what about z06 wheel sizes, does it make a differencE?
should i run it at 30psi too?
im currently at 34
Old Feb 12, 2006 | 09:22 AM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
I have played with this for two years, 30 cold seems to give the best mileage during the cold months. Spring & summer I drop it to 27-28 cold any lower & it sets off the low tire warnings.
Good luck
Old Feb 12, 2006 | 10:02 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
I don't want to make a career out of checking the pressure in my tires. So ...
