My 2001 battery died and wanted to get the Optima Red Top (Mag Red painted covers inside) and wanted to know the part number as I went to Auto Zone and had a couple different mode numbers as they were out of stock. Thanks alot.
There are two different versions of the red top. Get the 34/78. It's the one that has 800 Cold Cranking Amp capacity and is the better choice of the two. It costs a bit more than the other (35/75) version, but worth it. The parts seller there may try to tell you the 35/75 is "what's recommended/listed" for C5's and he/she/it may be right. About the listing that is. Get the 34/78 even if you have to order it in. Trust me you won't regret it.
HTH,
Robert
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The 75/35 (also now known as the 75/25) is 720 cca. The 34/78 is 800 cca - a little bigger and a little heavier. Both will fit with no issues, and you won't be making a mistake with either one. Personally I have a 75/35 that I bought 2 1/2 years ago - and have not had one issue with it.
I have had trouble free dependable performance, and, quality in construction with no leaks, etc., or, problems of any kind in the now four years that I have had the Red Top Optima Battery in my DD C5.
Sam's Club sells the Exide Orbital spiral cell Battery under their NASCAR XLT brand with a 3 year warranty for $95 ( 35 series) or $99 ( 34 series)
It is a good alternative at a good price with a great warranty
