Power steering pump leak...
Old Feb 11, 2006 | 11:55 AM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Default Power steering pump leak...
Hi folks,
Being the cheap bastage that I am, I will probably change the seal rather than the pump ($20 -vs- $200). Anyone had this issue before? Never seen it posted here and nuthin on the search.
Doesn't look to be much of a pita, but if anyone here has done it and knows otherwise, please share your pain...
Thanks in advance...
-Curry
Old Feb 11, 2006 | 12:37 PM
Paras's Avatar
Paras
Can't help you but I was wondering what sort of sound if any a leaky pump makes... I get a whine at some points when I'm turning--can't tell if its the swaybar or the steering...
Old Feb 12, 2006 | 12:11 PM
devnull's Avatar
devnull
Hi Paras,
No sound, just a few drops here and there on the garage floor...
Thanks,
-C
Old Feb 12, 2006 | 03:21 PM
Paras's Avatar
Paras
Cool, thanks...
Old Feb 12, 2006 | 04:11 PM
BBates's Avatar
BBates
My '97 had a leak last summer. Mine was the high pressure line from the pump to the rack. I went ahead and replaced all the lines including the power steering cooler. I got all of the parts from Gene @ Fread Beans. With the help of Razor2430 we fixed it up in a couple of hours. No trouble since. Good luck. B
Old Feb 12, 2006 | 05:02 PM
devnull's Avatar
devnull
Hmmm.. now that you say that, it might be the same thing...
I will get the hose also...
Thanks!
To Power steering pump leak...
