Do you have an example of a fob for your car to compare?
Info from the C5 general sticky post
Originally Posted by the_sticky
Key Fobs
There are basically two different kinds of key fobs, and they are not compatible with each other.
97-00, but 00 does not have the Passive Lock feature
01-04
Both remotes use a CR2450 coin type battery. I found replacement batteries at Office Depot. To replace, use a coin to wedge between the seam, and twist.
Ref: Service manual, page 8-747.
Originally Posted by vette747
Fob programming
1-Turn the ignition to RUN
2-Turn the radio off
3-Press the RESET button in order to clear any IPC warning messages
4-Press the Option button on the DIC until the IPC display is blank in order to enter the program mode
5-Press and hold the Reset button for 3 seconds
6-Press the option button until FOB Training message is displayed
7-Press the Reset button in order to begin the programming sequence.
8-Simultaneously press and hold the lock an unlock buttons on the first transmitter for 12 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this step for each transmitter.
I just bought some from the guys at Ken Fichtner Chevrolet. I bought two of the passive style (with the little switch on it for passive lock/unlock) for our 99 coupe. They gave me quite a break from list.
I lost one of them for the 99, and then the other one quit working.
The 2000 key fob in part number 10432147. Good Luck. I have tried to buy some on e-bay and get out bidded by a major vendor of key fobs. Get a dealer price to make sure that you don not pay to much.
PN 10432147, about $90.00 shipped, at Gene@FredBeans. List is about $131.00
Geez !!! I was thinking about getting a new one because the lettering on one of mine is pretty much worn off. It still works ok, so to the tune og 90-130 bucks, I "ll live with it or just switch to the spare one which rarely been used.
Let me know if you want to get rid of the worn one!!!
I need another remote for my 2000 coupe. How do I know which one to get? There are many on eBay but I'm not sure how to know if they are compatible.
Thanks!!
When i purchased my 01 Z06 it only came with one key and remote, the second one apparently was destroyed some time ago and it was never replaced. Long story short, i went to a local dealer and had to get a new key cut and remote programed (had to have a back up), and both of them only ran me $95 out the door.
How are you guys getting prices of $90 to $130 for just the remote? Did my dealer just make an error in pricing me out my key and remote???
You definitely got a good deal for a new remote and new key. The absolute lowest price I've seen for a brand new remote is $74.64. The list price is $130.00.
The FOBs for 2001-2004 are only $44.52, list. So you paid $50.00 for the VATS key?
That is the later style fob without the passive feature, and it is not the "fat" fob. gmpartsdirect lists the GM list price as $44.52, but they sell them for $25.
The 97-99 passive style fobs list for well over $100, but I bought mine from Fichtner (forum vendor....) and for two of the more expensive passive fobs and a new key for my 99 the total was under $200 delivered to my house, so the fobs were around $65 each and the key was around $30 if I remember. correctly.
