[Z06] VB and P Bushings
What will these do for the handling and feel of my car?
Will my lap times improve and if so, how much will they help?
I have been thinking about the effect the stock softer rubber bushings are likely to have on the car now. I have a slight toe-out (1/8 total) and a slight toe-in (1/8 total) on the rear.
It seem that with softer rubber bushings that I would get a slight bit of flex in the bushings adding more toe-in on heavy trail braking into a turn which I like to do. And then on power out a little flex in the rear is going to add a little more toe-in, perhaps a good thing.
I know I am thinking out of the box here and challenging existing notions, but I guess I am known for that around my parts. So it is a bit of a whacky thought I know, but perhaps a little bit of flex from the stock bushings can add a desirable variable toe effect on the car.
I have only driven with stock bushings and therefore I do not know the feel and characteristics of poly bushings. Does anyone have any feedback on this?
An even better test is actual timed results from controlled experiments with these bushings. Do these test results exist?
Anyway, this sounds like it might make for fun debate.
Seriously though, what do you smart veterans know about this?
All, said VB&Ps will improve the handling and steering response of the car, but at the cost of a little street compliance. Will it make times drop, I doubt it, but it'll make the car feel better, which makes the driver more comfortable/confident, which results in faster drivng.
My car now probably sees nearly as many track miles as street miles. My stock bushings are starting to get a little beat-up so I am looking for the most reasonable replacement.
Mine were greased like a b&tch when installed and started squeaking horrible after 6 months. To the point, that I probably couldn't sell the car.
That aside the handling improvement was less than 10%.
I replaced mine because some of my stock bushings needed to be replaced. I should have stayed with rubber. If I could do it again, I would stay with rubber.
