Changing to 18" fronts?
Old Feb 12, 2006 | 12:49 PM
captainpooby's Avatar
captainpooby
Default Changing to 18" fronts?
What does it do to the geometry of the car if you go from 17s to 18s on the front?
It will raise the front .5" but does that affect the handling? Do you compensate by lowering the nose .5 or lower profile tire?
Old Feb 12, 2006 | 01:15 PM
FKING1's Avatar
FKING1
All you need is an alignment.
Fred
Old Feb 12, 2006 | 01:22 PM
Paras's Avatar
Paras
I've heard some folks say that going to 18s up front improves handling...
Old Feb 12, 2006 | 02:20 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Get a lower profile tire. The end result (wheel and tire) is the same as stock.
Old Feb 12, 2006 | 02:28 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
You can use the setup I ran before as a scale.It worked without any computer problems(which I was concerned about)
275/35/18 front 295/35/18 rears.No issues
Old Feb 12, 2006 | 02:48 PM
Paras's Avatar
Paras
Hmmm... it almost seems like you could just put your stock rear wheels&tires - 275/40/18 on the front...
Old Feb 12, 2006 | 03:09 PM
mixermike's Avatar
mixermike
that is what i've been thinking lately then buy bigger wheels and tires for the rear. 18s or maybe 19s ?
Old Feb 12, 2006 | 06:12 PM
lostremote's Avatar
lostremote
ive used 19" pirellis all around withh ccw sp20a chrome rims looks & rides awesome
Old Feb 12, 2006 | 06:22 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Any time you alter the wheel/tire sizes, your primary goal should be to keep the height (diameter) of the tire about the same.
I'm running 19" fronts, and the tire height is identical to those of the stock 17's.
Old Feb 12, 2006 | 08:30 PM
brunog's Avatar
brunog
I have 18's in front and 19's in rear. I slammed the car as well.
Old Feb 12, 2006 | 09:18 PM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
As long as you keep the same proportions in tire sizes, you'll be fine. Otherwises, you might have active handling and traction control problems.
I'm running 265/35/18s in the front and 295/35/18s in the back using 18x9.5/18x10.5 high polished Y2k wheels.
Old Feb 12, 2006 | 10:05 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
StuzVette
Front 18X9.5 285 35 18
Rear 18X10.5 305 35 18
good variation in front and rear height
lowered on stock bolts
Hotchkis sway with adjustable links fron and rear
and Bilstein shocks...
Awesome ride and handling is extraordinary!
Old Feb 12, 2006 | 10:27 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
I'm running 265/35/18s in the front and 295/35/18s in the back, lowered 1" all around
Old Feb 12, 2006 | 10:54 PM
IDM's Avatar
IDM
Do not do this, it causes major problems with the Traction Control.
265/35/18 and 295/35/18 are correct sizes.
I don't know about better handling but 18s up front look very nice, the back could use 19s in my opinion
Old Feb 12, 2006 | 11:12 PM
Paras's Avatar
Paras
Good to know--You should probably be able to fit tires of this sort on the stock rear rims, right?
Old Feb 13, 2006 | 12:20 AM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
I've been running the 275/35/18 fronts and 295/35/18 rear for over a year and a half with ZERO issues and some others have as well.. I would personally run these again..
Old Feb 13, 2006 | 12:28 AM
IDM's Avatar
IDM
He said 40. The aspect ratio of 40 is NOT fine in the situation. 275/35/18 I'm sure is ok.
Paras I'm not sure what your question is.
To Changing to 18" fronts?
